Barcode scanning to run gcode
07 Apr 2016 11:41 - 07 Apr 2016 11:50 #72901 by BigJohnT
Replied by BigJohnT on topic Barcode scanning to open gcode
A very short video showing it working.
JT
Last edit: 07 Apr 2016 11:50 by BigJohnT.
  • eFalegname
  • eFalegname's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Apr 2016 23:03 #72936 by eFalegname
Replied by eFalegname on topic Barcode scanning to open gcode
Hi JT, thank you very much for the script but I'm trying and trying and I can not get it to work properly... :sick:
07 Apr 2016 23:08 #72938 by BigJohnT
Can you be specific as to the error/problem? I can't even guess what is wrong without some actual info.
JT
  • eFalegname
  • Elite Member
  • Elite Member
09 Apr 2016 09:17 - 09 Apr 2016 09:18 #72991 by eFalegname
Hi JT
Sorry for not answering quickier, I was controlling where was my error, I was writing the full path to the gcode file, now is ok. The fact is that there are too many clicks to do for the operator, I would like a way were I just have to point the label and the gcode runs. My barcode scanner arrived it is the BCST-20 1D model from inateck , I might have done wrong not buying a 2D instead. Thanks a lot for the script and your patience, if you could modify it to make it more operator friendly and make it work also with a barcode scanner.
Last edit: 09 Apr 2016 09:18 by eFalegname.
09 Apr 2016 10:44 #72996 by BigJohnT
Hi JT
Sure thing, just send me a QR bar code scanner.
JT
  • eFalegname
  • Elite Member
  • Elite Member
09 Apr 2016 20:06 #73009 by eFalegname
JT
Hi JT
Fantastic idea!
Where are you? USA? I'm going to search for a convenient one and then I would need your address.
09 Apr 2016 21:02 #73013 by BigJohnT
Yes, I'm in Swamp East Missouri in the USA.
JT
  • eFalegname
  • Elite Member
  • Elite Member
13 Apr 2016 20:45 - 13 Apr 2016 20:46 #73250 by eFalegname
Hello guys, can any of you explain, please, what does this document meant. It seems to me that all those barcode scanner listed on the document are 100% compatible with Linux or I am wrong.
Do Honeywell hand held scanners interface with Linux?
Applies To
3800g, 3820, 3820i, 4600, 4620, 4800i, 4820i, 6300, 6320, 5600, 5620, 5800, 5820
Xenon 1900, Xenon 1902, Hyperion 1300g, Voyager 1200g, Voyager 1250g, Voyager 1202g, Vuquest 3310g, Voyager 1400g, Voyager 1450g
Linux
Last edit: 13 Apr 2016 20:46 by eFalegname.
13 Apr 2016 20:52 #73251 by beltramidave
Replied by beltramidave on topic Barcode scanning to open gcode
As stated early on in this post, I had used a 3800g to open files in Linuxcnc by creating a appropriate barcode.
  • eFalegname
  • Elite Member
  • Elite Member
13 Apr 2016 21:14 - 13 Apr 2016 21:42 #73254 by eFalegname
I had understood perfectly your post and I thank you, I have already taken a 1D barcode scanner compatible with linux, now I'm searching for a 2D one. I readed the manual for the Honeywell 3800g, it only reads 1D codes and the 2D Code PDF ...thanks to you my doubt is now clarified, it was just a language problem. Thank you
Last edit: 13 Apr 2016 21:42 by eFalegname.
