Threading with A B phase only?
9 years 8 months ago #88431 by Mtndrew77
There's a ton of info here wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test , but the Mesa card generates the step pulses so you shouldn't have an issue
9 years 8 months ago - 9 years 8 months ago #88437 by Stormbird
Oh that's good thanks. I have done all the bios stuff (disabling power saving features, virtualization, etc). When I disable multi-core processing to have only one of the duo 3ghz cores operating, the latency dropped significantly from 26000 to 20000 (1.0 ms) & 60000 to 30000 (25 us) which is interesting. Anyway I am ordering two NEMA34 1090oz steppers and drivers same as yours. Thanks again. Adam
Last edit: 9 years 8 months ago by Stormbird.
9 years 8 months ago - 9 years 8 months ago #88567 by Stormbird
So can I get some clarification on the method of LinuxCNC executing my operations please? I want 4 functions : 1) control of the carriage positioning motor, 2) control of the cross slide positioning motor, 3) control of the main spindle motor vfd for constant surface cutting speed which is dependent on the changing position of the cross slide, and 4) optional triggering of the thread cutting tool auto-withdrawal and auto-insertion which is dependant on the carriage position. Do the instructing signals from my pc LinucCNC program each go through the Mesa card 7i76e, and can the card run the drivers of different size motors simultaneously on different channels?
If I get a NEMA 23 for the cross slide leadscrew (little movement required in lathe work and also smaller is less obtrusive in fitting), a NEMA 34 for the carriage leadscrew and possibly a different type of motor altogether for the thread cutter auto-withdrawal mechanism (not quite sure yet exactly what that electrical mechanism is!), is that ok so long as each output channel does not exceed 5v? The threading auto withdrawal trigger is preset for dependency on the carriage position hitting a target, so will that be a separate output from the Mesa card or will it be from the same output channel as the carriage leadscrew driver takes its signal from? Also the spindle motor's vfd constant cutting surface speed operation takes its dependency on the position of the cross feed encoder - will that require an independent output from the card or will it be from the same output channel as the cross feed driver takes its signal from?
9 years 8 months ago #88571 by Mtndrew77
You won't need the old control display or the threading tool. LinuxCNC will display your position and with two axis control threading will be automatic. The old thread tool just had a solenoid that moved back and forth. You had to adjust the cross slide manually after each pass. Different size motors will not make a difference to the Mesa card. The card only sends step, direction, and enable signals to the driver.
9 years 8 months ago - 9 years 8 months ago #88576 by Stormbird
Fantastic. Thanks. As regards the constant surface cutting speed vfd function, 1) do the control signals from the pc for that function go (via the ethernet cable) to the Mesa card then to the vfd, or should they come out of a different pc port and go direct to the vfd. And 2) does LinuxCNC control have the option of selecting Modbus protocol to communicate with the my vfd?
9 years 8 months ago - 9 years 8 months ago #88593 by Stormbird
I can elegantly mount a NEMA 23 onto the left hand side of the carriage to drive the cross slide but only with a body length max around 56mm - this body length limit restricts me to a Stepperonline NEMA 23 178oz/in which is rather less power than one might like but then the cross slide is only making very small movements once operations commence and it is not driving a heavy carriage about like the main leadscrew is. The cross slide leadscrew has a reasonably light and smooth action for a 16 x 40 lathe. What do you think?...If gear it down a bit with a smaller pulley on the drive shaft....
Time to create page: 0.121 seconds
