Threading with A B phase only?
9 years 8 months ago - 9 years 8 months ago #88272 by Stormbird
OK so I have ordered the Mesa 7i76E for my EmcoMat-20E and it should arrive in the UK in a couple of weeks. Andy which specific models of Wantai steppers and drives did you go for ? Wantai do have an ebay shop and ship from Germany so hopefully import duty will be free for me. Thanks, Adam
Last edit: 9 years 8 months ago by Stormbird.
9 years 8 months ago #88310 by Mtndrew77
They were Nema34 1090oz in 5.6A. As long as you get a Nema34 size motor it will bolt right up to the old Z bracket but you will probably have to bore out the center of your bracket a little. The max speed I can get on my machine is 30 inch a minute with these
motors and the old lead screws. If you want better performance you might think about retrofitting a ballscrew. I wanted to convert to ballscrews but didn't want to spend the money at the time. I'm fixing up a little EMCO pc lathe right now and my hope is to use the money from that to finish converting the lathe and my bridgeport.
9 years 8 months ago - 9 years 8 months ago #88331 by Stormbird
Thanks for that - I thought for mills and lathes generally people go for more powerful NEMA 42's, and Wantai do describe the NEMA 34 1090 oz/in model as only an "engraver" motor, but I understand your choice of a Nema 34 size as a perfect fit (and cheaper than a 42). I think I would prefer to go for a more powerful one like the Wantai NEMA 34 1600 oz/in, or maybe the Stepperonline NEMA 34 1841 oz/in. Both of course more expensive and higher voltage, and still only about half the power of a 42. Or maybe fabricate a bracket with an idler pulley to squeeze a 42 in?
9 years 8 months ago #88337 by andypugh
No eBay APP ID and/or Cert ID defined in Kunena configurationMy 9 x 30 lathe was fine with NEMA 23 steppers.
Steppers get slower as they get bigger.NEMA 42 tend to be very slow.
You might want to consider the new wave of closed-loop steppers. These are stepper motors (Cheap) driven as brushless motors.
A random example, not a recommendation of model or supplier.
9 years 8 months ago #88340 by Stormbird
Ah I didn't know that thanks. Did you get the Wantai 2H Microstep Drivers (DQ860MC) with your 1090oz/in, steppers? Those same drivers are offered as a package with their 1600 oz/in NEMA34's....
9 years 8 months ago #88342 by Stormbird
Andy thanks but I think I'd prefer to be a sheep and keep it simple and use ordinary stepper motors like others do, at least then it is easier to bleat for help! The Encomat 20E is 8" x 40" or in America terminology I think 16" x 40". Other Andy of Mtndrew77 was saying that the main leadscrew feed was a little slow with NEMA34 1090 oz/in and could be speeded up by upgrading with a more efficient ball screw, hence i am thinking simpler just to up the power - their NEMA34 1600 oz/in is not really much more expensive and comes with the same drivers.
Time to create page: 0.117 seconds
