Threading with A B phase only?
10 years 1 month ago #80932 by Mtndrew77
Well it is but I guess it may not be exact since it is running off an idler shaft in the headstock. Didn't think of that one, but it makes the most sense to me
10 years 1 month ago #80944 by Mtndrew77
Could my 7i76E handle a 24V signal on the spindle encoder interface? With 5v signals on A,B and 24v on index?
10 years 1 month ago #80945 by PCW
Replied by PCW on topic Threading with A B phase only?
Not directly, but you can make a simple voltage divider with 2 resistors to get the signal down to a 5V level
24V index --> 1K Ohm 1W --> 250 Ohm 1/4w -->GND
the 5V signal is taken at the junction of the 1K and 250 Ohm resistors
The following user(s) said Thank You: Mtndrew77
10 years 1 month ago - 10 years 1 month ago #80993 by andypugh
Mtndrew77 wrote: Could my 7i76E handle a 24V signal on the spindle encoder interface? With 5v signals on A,B and 24v on index?
What type of proximity sensor is it? A 24V 3-wire NPN Prox can be connected directly to 5V logic (they act as a switch to GND, rather than a voltage output)
Last edit: 10 years 1 month ago by andypugh. Reason: Added "3-wire" to be more specific
10 years 1 month ago #80997 by newbynobi
A little bit off topic, but...
if I add such a switch to my lathe spindle, how fast will the switch react, or better ask what rpm might it be able to count?
It would be easier than adapt an encoder 1:1 to the spindle.
Norbert
10 years 1 month ago #80999 by andypugh
newbynobi wrote: if I add such a switch to my lathe spindle, how fast will the switch react, or better ask what rpm might it be able to count?
It doesn't really matter as long as it is consistent at the speed that you are running at.
And spindle-synchronised moves normally happen at fairly low spindle speeds.
Time to create page: 0.396 seconds
