Hi I am a hobbyist and I too have (just acquired) an Emcomat 20E with faulty electronics (so faulty that spindle drive nor feed drive works) and want to upgrade/swap out all the electronics to a modern control system (with DRO and quasi-CNC). I could maybe keep the stepper motors for feed and for the thread cutting auto insert/withdrawal, but will fit a smaller spindle drive motor to match my inverter for domestic supply which has a 3hp max limit (so will replace with a 2.2kw 3 phase dual voltage motor). I have found very little info from EMCO on the electronics although I do have a complete manual. In particular I cannot find any info on the Linear encoders to usefully find a matching DRO system, nor what program could set pitch diameters to the the existing leadscrew feed motor for thread cutting. In terms of control, I would ideally like to have allthe original program functions and add to those an ability to cut diagonal paths (in other words drive X and Z simultaneously). I would be very grateful to hear what you have done and at what cost. Kind regards, Adam
