LinuxCNC S-Curve Accelerations
- Grotius
- Thank you received: 2349
02 Jan 2022 07:50 #230550
by Grotius
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Just finished a template, where so far as i can see all scenario's are implemented for a traditional lineair curve.
This is a output that happens within 1 gcode line.
This includes :
code
video
This includes :
- User changes max velocity during program run.
- Target velocity can not be reached by input displacement.
- Curve up, curve down, curve steady.
- Curve respects max velocity.
code
video
The following user(s) said Thank You: Darium
- Grotius
03 Jan 2022 05:08 #230644
by Grotius
The following user(s) said Thank You: Bari, Darium
- Grotius
03 Jan 2022 07:11 #230648
by Grotius
- Grotius
04 Jan 2022 09:12 #230771
by Grotius
The following user(s) said Thank You: bkt, Lcvette, Darium
- bkt
- Thank you received: 114
13 Jan 2022 11:48 - 13 Jan 2022 13:58 #231684
by bkt
Replied by bkt on topic LinuxCNC S-Curve Accelerations
write on wrong place ... sorry
Last edit: 13 Jan 2022 13:58 by bkt.
- ViktorS
09 Feb 2022 20:25 #234448
by ViktorS
Replied by ViktorS on topic LinuxCNC S-Curve Accelerations
I thought I might shime in with some experience with how atleast some comercial cnc's handles this acceleration profile (Mazak Integrex and Cincinnati Arrow).
My Cincinnati Arrow has Siemens 2100e controller with die & mold package, which means S curve accelerations among other things.
This is a regular 3 axis vmc so no super advanced planning required. When doing moves that requires spindle sync, ie. rigid tapping or feed-per-tooth, it reverts back to trapezoidal acceleration profile. It will also use trapezoidal profile for jogging and handwheel.
The Integrex does not have true S curve profile but not trapezoidal either, rather something in between. This is a 5 axis millturn btw.
But this machine will also revert back to trapezoidal acceleration when doing rigid tapping and also thread turning or hobbing.
It will not use trapezoidal for feed-per-revolution feedrate, and thank god for that as a lot of turning involves 90 degree direction changes.
The point is that for lathes and mills an S curve sync'ed spindle is not really used in any situation. Trying to do rigid tapping when moving on the last bit of that S profile would probably stall the spindle during such a move.
Now of course linuxCNC probably have uses for S curve synced spindle far beyond what I can see, but when it comes to milling or turning it seems that is not required. In fact both above machines have a modal G code to activate S profile (and some advanced lookahead) separately from standard trapezoidal.
Other than that, thank you for pushing this forward! It's a really crucial feature.
The following user(s) said Thank You: Lcvette, Darium
- TheRoslyak
- Thank you received: 37
12 Apr 2022 09:59 #240051
by TheRoslyak
Replied by TheRoslyak on topic LinuxCNC S-Curve Accelerations
hi arvidb
I haven't been on the forum for a long time.
I wanted to know if it was possible to solve the problem that I understood on forum.linuxcnc.org/38-general-linuxcnc-q...elerations?start=210
- Thank you received: 4154
12 Apr 2022 14:06 - 12 Apr 2022 14:08 #240072
Replied by rodw on topic LinuxCNC S-Curve Accelerations
If you are referring to installing ethercat, yes its solved by using a repository containing IgH Etherlabmaster maintained by them
I wrote a Sticky on it in the Ethercat section on how to do this.
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Everything else uses an obsolate version of the IgH source code on Mercurial when their repositories have moved to gitlab
Next on the agenda is a custom homing module for cia402 ethercat drives.
I would suggest building linuxcnc on Debian Bullseye from source and follow that sticky using these instructions
www.qtpyvcp.com/install/bullseye.html
Last edit: 12 Apr 2022 14:08 by rodw.
- arvidb
- Thank you received: 158
13 Apr 2022 02:44 #240116
by arvidb
The integration of my jerk limited jog planner is not done yet, no. I'm still working on it now and then, when I can find enough time and energy. I did get some significant preparatory patches into master recently. Lots of work still left to do though. Untangling the innards of motmod enough to enable modular jog planning is a large undertaking, and that's pretty much what I'm doing.
Replied by arvidb on topic LinuxCNC S-Curve Accelerations
Hi TheRoslyak,hi arvidb
- abs32
28 Oct 2022 10:58 #255308
by abs32
Colleague, all the Githab links you cited above are dead, I can't download anything. Please share information about the current state of things.
I would like to implement the s-curve feature in my LinuxCNC2.8 example and would appreciate any help, guidance, instructions, links, etc.
Replied by abs32 on topic LinuxCNC S-Curve Accelerations
Now i can try to apply the the scurve algo to this working demo.
code
video
[/list]
Time to create page: 0.632 seconds
