It's been reworked by YangYang, 9D branch will probably be abandoned, in favor of whatever YangYang comes up with, it's loosely based on my work form 9D branch. What we are working on now internally, which I was going to talk in the next meeting, is a pre-processing library, as we are testing Yangyang's TP2 internally before release, we found that the last few jerk spikes were caused by segments that are shorter than a cycle time, there is just no time to do proper calculations on them, the pre-processing will be a toggle in the INI file, the library will be called Liscio, also renaming Ruckig to Scatti cause that's what we talked about with smoe in the mailing-list, and YangYang can't pronounce Ruckig image missing /media/kunena/emoticons/laughing.png
Anyway Liscio will create a smooth path with NURBS, still early stages, would love some test gcodes from the community, so we can kink out most issue internally before release.
There is precedence commercially with Fanuc I believe, they are doing similar work, probably others as well.
