- Thank you received: 134
It will not add any delay as it should be applied as the acceleration is calculated or read per servo cycle. Just not sure how you need to use it.Yes Rod .. it is solution but it is creating constant delay between control position -> DFIR -> current position of tool ....
I think the best way to apply that... its consulate with Luca or Yang Yang if they are allready not using something like that now... I'm not that familiar with their code till now ... it toooo way complicated for meYes Rod .. it is solution but it is creating constant delay between control position -> DFIR -> current position of tool ....
the size of the buffer is configurable.
Any other published moving average solution wanted to use loops which are a source of delay so I devised this..
One of the cleverest algorithms I have ever coded...
Thanks, I've been wondering too. I've been dreaming about kinematics using multiple realtime threads. Does anyone know whether/why it would not do?Why can't you use more than one thread instead of a FGPA?
Just now I discovered:Go easy on me. I tried to read through this whole thread, but there's a lot to digest.
--snip--
I know it's not a "real" control, but it's pretty amazing they could get all that to work (along with g-code interpreter, etc) on an 8 bit AVR microcontroller.
