- Thank you received: 4153
Grotius wrote: Hi Rodw,
I implemented the adaptive-feed option in Gmocappy. It's not working negative on the version 1:2.8.0 pre. Pcw know's this also i think. The function is working only on value's 0.0 to 1 for full adaptive speed combined with the Macro code M52 P1. The only float in command left is analog in. But this is unusable for negative feed. Also a negative g-code value gives error on the g-code intepreter.
I have not looked in the intepreter source code. Maybe here is possibility.
Tricking the system is not possible also if you use a negative feedrate.
The most quick way is to change a few lines of code in the command.c file and a few other files. The log's for how to do this lives on github. It's not very difficult. Just copy past... en delete some lines of code.
But i can not find this "command.c" file on my system. I only see this file in the github download's. But on my system i don't know where it's located. Also i have no file search function in Thunar. Maybe someone know's how to.... Maybe the file is gone after compiling linux on your system?
The A and B axis are for machine's that need this axis. For example my tube cutter go's up to 5 axis. Also i have gantry machines
with double head's or side tube cutters.
image missing http://www.grotius-cnc-machines.nl/wp-content/uploads/2017/10/Grotius-CNC-Tube-Cutter.gif
For me is learning linux cnc a investment in the future of my company. It takes a time. But in the end you have almost
unlimited possibilities.
Here is a waterjet with 5 axis. ( 1 stepper for grid supply to the waterjet nozzle. ) Also a ceramic beared milling unit.
This is an old type of machine for me. The newest types are very cool and more hufter proof guide way protection.
image missing http://www.grotius-cnc-machines.nl/wp-content/uploads/2017/10/Grotius-CNC-Waterjet-Accustream-Hyprecision.gif
This is a new type of machine, with integral guiding and drive system. Also 4 axis. Working area : 3000x6300x180mm
image missing http://www.grotius-cnc-machines.nl/wp-content/uploads/2017/10/Grotius-CNC-Autogeen-1.gif
Maybe i must contact Norbert. He can do a great job for me.
