gscreen industrial virtual keyboard on Debian strech
- mpvriens
01 Feb 2018 10:22 #105276
by mpvriens
gscreen industrial virtual keyboard on Debian strech was created by mpvriens
would like to use the virtual keyboard on gscreen industrial with Debian strech.
Have installed matchbox, and is working through the terminal, but how to open it through gscreen ind.?
- Thank you received: 2181
01 Feb 2018 17:17 #105289
Replied by cmorley on topic gscreen industrial virtual keyboard on Debian strech
What version of linuxcnc are you using?
I believe this should work in master - ill have to check in 2.7
Chris M
Chris M
01 Feb 2018 17:22 #105290
The code for matchbox is not in 2.7
Chris M
Chris M
01 Feb 2018 17:50 #105291
i should mention - if you wish to use matchbox with the 2.7 version that is possible - by adding some python code to a file.
It should be pretty painless.
Chris M
Chris M
- mpvriens
02 Feb 2018 10:44 #105321
by mpvriens
Replied by mpvriens on topic gscreen industrial virtual keyboard on Debian strech
Hi Chris
Thanks for your respond, tried to update to master with "Buildbot"ends up with error : Package Linuxcnc is not available, but is refererred to by another package.( when i try to install linuxcnc)
What python code should i ad to 2.7 , as this works fine at this moment.
Marius
Marius
02 Feb 2018 21:04 #105339
In the interest of simplicity I added the code to the file.
Place this file in the configuration folder you are using industrial in.
Gscreen will use this handler file rather then the internal one.
For some reason I can't post a python file on here directly so I compressed it - remember to un-compress it in the folder.
If all goes well matchbox should show.
Chris M
Chris M
- mpvriens
10 Feb 2018 10:36 #105695
by mpvriens
Hello Chris,
Have downloaded and un-compressed the handler-py file to my linuxcnc config folder, but can't start the matchbox
11 Feb 2018 00:25 #105728
I need more information.
start linuxcnc from a terminal.
It will print a lot of information to the terminal.
first try the show keyboard button and see if anything obvious prints in the terminal.
otherwise if you could copy and paste the text of the terminal when linuxcnc first starts I will look at it.
Chris M
Chris M
- mpvriens
14 Feb 2018 15:51 #105926
by mpvriens
Hi Chris,
When pressing keyboard button, no print on terminal,
14 Feb 2018 17:27 #105934
So then I need the information printed when you first start linuxcnc - it will tell me if it is loading the modified file or the default file.
Chris M
Chris M
Time to create page: 0.239 seconds
