gscreen industrial virtual keyboard on Debian strech
- mpvriens
15 Feb 2018 08:41 #105971
by mpvriens
Replied by mpvriens on topic gscreen industrial virtual keyboard on Debian strech
see screenshot
- Thank you received: 2181
15 Feb 2018 20:23 #105988
Replied by cmorley on topic gscreen industrial virtual keyboard on Debian strech
Well it is using the modified file:
**** GSCREEN INFO: handler file path:
have you modified the GLADE file?
Could you post your whole config here and I'll look at it?
If not I'll get you to add some debugging print statements.
Sorry it should have been easier then this
Chris M
Chris M
- mpvriens
19 Feb 2018 16:56 - 19 Feb 2018 16:57 #106172
by mpvriens
Hi Chris,
Some result, at leased when toggle the keyboard button it generates some figures, attached the config, and screen print
(have temp. renamed industrial_handler.pyc to add it to this post)
Attachment not found
Last edit: 19 Feb 2018 16:57 by mpvriens.
19 Feb 2018 18:10 #106176
something went wrong there is no attachments.
probably easiest to zip the whole config folder and post
Chris M
Chris M
- mpvriens
20 Feb 2018 06:55 #106216
by mpvriens
- mpvriens
20 Feb 2018 06:58 #106217
by mpvriens
Also have attached the printscreen
20 Feb 2018 07:23 #106218
Hmmm well it works fine for me
If you open a terminal and type :
matchbox-keyboard
Does it display?
Chris M
matchbox-keyboard
Does it display?
Chris M
- mpvriens
20 Feb 2018 09:45 #106223
by mpvriens
Yes when I open terminal and type: matchbox-keyboard, it display the keyboard, only on my linux g-screen it would not appear
- Thank you received: 4149
20 Feb 2018 13:15 #106233
Replied by rodw on topic gscreen industrial virtual keyboard on Debian strech
I don't know if its relevant but I could never get matchbox to work with gmoccappy so I used onboard instead. It has had a bit of a checkered history with Linux Mint and it disappeared from my config but now its back in the repositories. I found I had to add a startup command to start it otherwise it did not display.
- mpvriens
20 Feb 2018 13:20 #106234
by mpvriens
As far as i could find, "onboard"is not supported by Debian strech
Time to create page: 0.418 seconds
