Optical encoders with DC motors
8 years 7 months ago #108047 by cptX
Hi to all,
lately I am playing with optical encoders and DC motors, all taken from old printers.
With arduino I have full control over them. I also implemented a digital PID to control their position.
Now I would like to use them with LinuxCNC.
As I have read here LinuxCNC has the capability to work with encoders (see linuxcnc.org/docs/ja/html/man/man9/encoder.9.html )
but I don't understand some things at this point:
1. What hardware do I need to feed the input signals of the encoders to the parallel port and ouput suitable signals for the H-Bridges to control the DC motors (1 PWM and 1 Direction signal per motor).
2. How to configure the software to run these motors. Should I trim the PIDs inside LinuxCNC for each axis/motor?
3. Is there a way to use my hardware measured position (from arduino) and feed this info to LinuxCNC?
4. Can I use arduino as a form of servo motor and send position commands to it through LinuxCNC? I know by this way is not actually a complete closed loop system as LinuxCNC will not have the primary feedback of the position.
Any help would much appreciated
8 years 7 months ago #108052 by cptX
Answering my own question, I found the following related infos:
www.forum.linuxcnc.org/27-driver-boards/...ncoders-and-h-bridge
emergent.unpythonic.net/projects/01142347802
www.forum.linuxcnc.org/49-basic-configur...tch-servo-for-3-axis
So looks like it is possible for 2 and maybe even 3 axes.
8 years 7 months ago - 8 years 7 months ago #108061 by cptX
No eBay APP ID and/or Cert ID defined in Kunena configurationHi tommylight, this is exactly what I want to do. I also found this board in ebay and considering buying it.
How did you produce the PWM and DIR signals from LinuxCNC? Do you have any code you could share with us?
Have you tried any modifications to introduce a 3rd axis or you spent all the I/O of the parallel port?
Have you connected the optical encoders directly to the parallel port? If so how, through simple resistors or through optocouplers?
Why not use this board instead of yours , is this only for one motor?
Last edit: 8 years 7 months ago by cptX.
8 years 7 months ago #108092 by tommylight
Linuxcnc can output PWM to parallel port easily. The complete config with PyVCP panel as shown on the video is attached at the end of that post.
You can do 4 axis on a single parallel port in mode X, but there will be no more I/O left aside for a single input.
Yes encoders are connected directly to PP. Beware that some encoders will not work on mode X inputs doe to weak outputs.
You can also use that board with the same config, but i do not like it due to very low motor voltage. The ones i have i can change MosFets at will with more powerful or ones that can withstand much higher voltages. It should be for 2 motors, that is what it says in the link you posted.
8 years 7 months ago #108163 by cptX
Hi guys, yesterday I had a huge progress!
Using the etch servo example and a single L293D chip on a breadboard connected to the parallel port I managed to control the head of a printer successfully (normal dc motor with linear optical encoder). Trimming the PID was the most difficult part of the story, but yeah it works!!
LinuxCNC is amazing, it can do everything!!
Now I need to research if I could make 3 axes instead of normal two ones described in the example...
@tommylight thanks for the tip for "mode X". I didn't know it was existing. Right now I have configured BIOS to "EPP" but I checked and there is "Bi-Directional" mode which I suppose is the "mode X".
Theoretically to make a 3 axes cnc I need 9 inputs and at least 6 outputs:
2 Inputs per channel for optical encoders, 1 Input per channel for Home switch and 2 Outputs per channel (one for direction and one for pwm).
The current "etch servo" requires 3 outputs per channel to drive the L293D (or the L298) so I will need extra HW logic to convert the signal to two per channel. Right now etch-servo requires 9 outputs and "mode X" gives only 8 outputs...
Time to create page: 0.072 seconds
