Optical encoders with DC motors
- Skec
- Thank you received: 4
31 Aug 2020 18:10 #180204
by Skec
Replied by Skec on topic Optical encoders with DC motors
nice! That is sufficient for me. I want to drive small dvd rom dc motors, that pushes out the shelf for CD/DVD. I assume I could use Etch example from LinuxCNC library, and modify code so, that there is no more encoder part.(?)
- Thank you received: 7463
31 Aug 2020 18:24 #180209
Replied by tommylight on topic Optical encoders with DC motors
Using spindle PWM should be much easier. Set up a spindle using stepconf, wire the L298 inputs to the spindle parallel port output and it should run. You can also use the spindle-on pin to enable and disable the L298
- Skec
31 Aug 2020 19:04 #180211
by Skec
That is fantastic tommylight! I set up L298N through stepconf as PWM. And it runs. I can control DC motor movement through Spindle STOP button. CW and CCW also works. However, I can only turn dc motor ON or OFF, and then it spins on its own. I would love to be able to control it through "+" and "-" in continuous mode using mouse. If it could spin while I keep pressing "+" or "-" with mouse - it would be perfect.
31 Aug 2020 20:26 #180219
Does pressing + and - near the spindle button do anything ?
- Skec
31 Aug 2020 20:31 #180222
by Skec
It increases and decreases the speed. If I choose 0 Hz in config, then + or - starts the dc motor CW or CCW depending which one I press. But still, DC motor spins continuously once I press + or -.
31 Aug 2020 20:37 #180224
That is exactly how it should work.
If you want to do some more testing, try running some gcode with something like this in it:That will run the motor CW for 5 seconds at 100 RPM then run CCW for 10 seconds at 200RPM, then stop.
M3 S100
G04 P5
M4 S200
G04 P10
M5
%Please Log in or Create an account to join the conversation.
Time to create page: 0.262 seconds
