Gcode sharing folder ( Debian / Windows 7)
  • ozzyrob
  • New Member
  • New Member
8 years 5 months ago - 8 years 5 months ago #110906 by ozzyrob
Replied by ozzyrob on topic Gcode sharing folder ( Debian / Windows 7)
Allenwg2005
This may prove helpful, tho not thru a gui, but it is a step by step guide
hometechbits.wordpress.com/2017/11/05/de...ezy-dropbox-install/
If you are running a 32 bit version use this command to download
cd ~ && wget -O - " www.dropbox.com/download?plat=lnx.x86 " | tar xzf -
Personally I think dropbox is not quite the right tool for this job, unless of course all your CAM & CAD is being done on another site. I'd run a latency test whilst dropbox is running in the background to see if it has any affect. I have notice that turning off unneeded services (background programs) can result in a slight improvement in latencies.
Last edit: 8 years 5 months ago by ozzyrob.
8 years 5 months ago #110908 by allenwg2005
This is an interesting option, I have been wondering if Dropbox is not working (installing) for good reason (or intensionally). You make a good argument for other Network Sharing methods, can or will Dropbox create latency issues.
I think Andy's suggestion may make the most sense given some of the unknowns.
Thanks for the links.
  • ozzyrob
  • New Member
  • New Member
8 years 5 months ago #110910 by ozzyrob
Earlier in this thread I posted some info about setting up a samba share, an example I pulled from my server.
Another option maybe if your router has file sharing options to harness that. Some have USB ports where you can insert a flash drive or HDD and use that to share files. Usually it's just a "point & click" exercise.
Samba:
debian-handbook.info/browse/stable/sect....rver-with-samba.html
www.techrepublic.com/article/how-to-set-...-sharing-with-samba/
8 years 5 months ago #110939 by allenwg2005
I'm almost there, I have Windows set-up to share the folder I want, I have samba installed and the Network folder in my file manager, I can see the Windows folders, but it tells me it can't mount the folder in the "Shared folder" I made.
Can someone help me with this last thing please?
THX
  • ozzyrob
  • New Member
  • New Member
8 years 5 months ago #110943 by ozzyrob
As a rough guess I'd say that is more than likely a permission issue, I made an assumption that you are using windows 7, 8 0r 10. I haven't done much sharing of windows folders to linux since XP so please forgive me if I'm sending you up the wrong tree.
If that is the case maybe this link will help
www.howtogeek.com/176471/how-to-share-fi...n-windows-and-linux/
Sharing from linux to windows is easy, but windows to linux can be a pain.
8 years 5 months ago #111126 by allenwg2005
That was the set of instruction I used to get as far as I did. LOL
Everything looks like it should work in Windows (not that helps), any other suggestions?
Time to create page: 0.346 seconds
