Gcode sharing folder ( Debian / Windows 7)
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
25 May 2018 21:44 #111127 by ozzyrob
Replied by ozzyrob on topic Gcode sharing folder ( Debian / Windows 7)
Have you rechecked the permissions on the windows side ?
The windows user that has permissions to the folder is the one you are using to connect with ? This maybe different to the user you are logged in with at your linux machine.
You'll have to give more verbose descriptions of the errors you are getting.
Have a look at any log files contained here:
/var/log/samba/
This log file:
/var/log/syslog
Only look at the files that have a timestamp close to the time you were trying to connect. It will also help to know which versions of windows you are trying to connect to.
26 May 2018 17:39 #111156 by allenwg2005
Replied by allenwg2005 on topic Gcode sharing folder ( Debian / Windows 7)
Windows side
I have checked and rechecked permission on the Windows side and it appears I have that set correctly.
(Oh, it's Windows 7 Pro).
Linux side
I think I'm logged in correctly, all I get for an error message when I try to open the shared folder on the Win machine from the Linux machine is:
"Failed to open file XXXXX"
Failed to mount Windows share.
This could be a tell, I don't have permission to access var/log/samba, it has the red X next to it.
I used to know how to know how to change permissions but I don't recall how to do it now.
/var/log/syslog doesn't exist, (that could be telling me something as well).
Quit the adventure I must say, thanks for hanging in there with all your help.
26 May 2018 17:45 #111157 by allenwg2005
I found /var/log/syslog, it too requires permission which I don't have.
I'll try to do a search on how to change that.
26 May 2018 19:49 #111164 by allenwg2005
Also, I'm not following what this means:
mkdir: invalid option -- 'o'
26 May 2018 21:04 #111170 by allenwg2005
I'm not sure this is progress or not.
Now the error message says:
"Failed to open directory"
Permission denied.
I assume I'm back to Windows. (Man there are a lot of places to screw-up on Windows).
26 May 2018 22:36 #111171 by allenwg2005
I haven't any idea how I did it, but it works now, I can access the shared folder on the Win PC from LCNC.
Last question, when I go to load an .ngc file from within LCNC were do I find the network or shared folder?
That file path is eluding me.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
26 May 2018 23:08 #111172 by ozzyrob
Open a terminal and type
mount
Hopefully there will be an entry that starts with gvfsd-fuse on
If you cd into the directory and run ls
you hopefully with get an entry starting with smb-share:
eg I mount a share called movies02 on a server called subsonic and the entry is
smb-share:server=subsonic,share=movies02
so the full path would be (in my case)
/run/user/1000/gvfs/smb-share:server=subsonic,share=movies02/
This thread post discusses mount via fstab (you can choose where to mount the folder)
The second answer here discusses doing the same thing but using a file to store username & password, I would guess the domain entry could be left off.
If I had a windows 7 machine at home I could nail a full solution for you.
26 May 2018 23:59 #111173 by allenwg2005
Here is what mount yelled:
allen@CNC:~$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,relatime,size=10240k,nr_inodes=213733,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=335696k,mode=755)
/dev/disk/by-uuid/100f21bf-db51-49d3-b79f-e113983e3fa8 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1313640k)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw,relatime)
allen@CNC:~$
I didn't see anything here with gvfsd-fuse , I will look at those other answers you mentioned
Thanks again
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
27 May 2018 01:14 - 27 May 2018 01:16 #111175 by ozzyrob
OK
First you want to
sudo apt-get install gvfs-fuse
sudo adduser your-user-name fuse
Then logout and log back in and mount your share
The folder should then be in /home/your-user-name/.gvfs
your-user-name refers to your Linuxcnc login, which can be found by typing whoami at a terminal.
Sorry about the info before hand I was using Linux Mint and wrongly assumed things would be similar. I did the above after booting with the linuxcnc iso in a virtual machine and mounting a share on a linux samba server. The location of the mount should be the same.
Last edit: 27 May 2018 01:16 by ozzyrob.
27 May 2018 03:01 #111177 by andypugh
Replied by andypugh on topic Gcode sharing folder ( Debian / Windows 7)
Possibly in /mnt/hgfs
(Not something I would ever class as obvious)
I seem to recall it is much easier to find from the Linux file manager (whre it is under Network than from the LinuxCNC file picker.
The following user(s) said Thank You: allenwg2005
Time to create page: 0.527 seconds
