Ok I got dropbox to install.
First I started with a clean install of linuxcnc from the official iso.
Open a terminal
1: Update apt:
sudo apt-get update
[hr]
2: Update wheezy packages:
sudo apt-get dist-upgrade
[hr]
3: Add dropbox to sources.
a: run mousepad as root with following command:
b: add the line as follows (with carriage return at end ie press return): deb
linux.dropbox.com/debian
wheezy main
c: save as /etc/apt/sources.list.d/dropbox.list
[hr]
4: Import key
sudo apt-key adv --keyserver pgp.mit.edu --recv-keys 1C61A2656FB57B7E4DE0F4C1FC918B335044912E
[hr]
5: Update apt:
sudo apt-get update
[hr]
6: Install python-gpgme & dropbox installer
sudo apt-get install python-gpgme dropbox
[hr]
7: Start the dropbox installer from Application-Menu > Internet -Dropbox
[hr]
8: Just follow the prompts and off you go. Pressing OK will download and install the dropbox daemon.
[hr]
I don't have a dropbox account (it's deactivated) so haven't done any full testing but hopefully this should get you to point where you can at least install drop box and start cooking with gas.
Account is going again, two files synced to my computer from dropbox.
Uploaded file via web interface, was synced and placed in dropbox folder when starting up......So I guess it works. Haven't really put drop box to use all that much.
