Adding a Mpg to a 7i85s
- Thank you received: 4151
04 May 2018 13:45 #110201
Replied by rodw on topic Adding a Mpg to a 7i85s
I'm not sure I got the right pins as I'm used to master branch which has some differences to earlier versions which I think Tormach is running
There is a pin that turns on when you are on the jog mode in halui. We'll use that as your missing input that you thought you needed a switch for. I might have the wrong one becasue you are jogging joints not axes (which is what I use in master). So have a look at the modes in halui and watch those pins in halshow. See where this takes you after testing and debugging.
loadrt or2 names=xen yen zen
addf xen
addf yen
addf zen
# the next 3 signals are already defined
net sxp.xen-button => xen.in0
net sxp.yen-button => yen.in0
net sxp.zen-button => zen.in0
net jog-mode <= halui.mode.is-teleop
net jog-mode => xen.in1
net jog-mode => yen.in1
net jog-mode => zen.in1
net xen.out => axis.0.jog-enable
net yen.out => axis.1.jog-enable
net zen.out => axis.2.jog-enableThere is a pin that turns on when you are on the jog mode in halui. We'll use that as your missing input that you thought you needed a switch for. I might have the wrong one becasue you are jogging joints not axes (which is what I use in master). So have a look at the modes in halui and watch those pins in halshow. See where this takes you after testing and debugging.
04 May 2018 14:09 #110203
Actually when I think about it as Techno said, you can only jog when the right mode is selected anyway so you can probably just setp the in1 values to 1 but tying it to the halui pin would be an interesting exercise (and probably a better solution)
setp xen.in1 1
setp yen.in1 1
setp zen.in1 1Please Log in or Create an account to join the conversation.
- Clive S
- Thank you received: 486
04 May 2018 14:32 - 04 May 2018 15:46 #110205
by Clive S
Replied by Clive S on topic Adding a Mpg to a 7i85s
Thank you for your time Rod. Unfortunately I will be away all next week so won't have time to test but I will report back on my return.
I have debugged it to here: this is the error message : custom_encoder.hal:26: Signal name 'xen.out' must not be the same as a pin.
loadrt or2 names=xen,yen,zen
addf xen servo-thread
addf yen servo-thread
addf zen servo-thread
Not sure how to correct this.
Last edit: 04 May 2018 15:46 by Clive S.
04 May 2018 20:58 #110220
I probably should have added a signal name
net xen-out xen.out => axis.0.jog-enable
- Clive S
05 May 2018 08:19 #110240
by Clive S
Thank you again Rod Success. I must have played with this for over 100 hours. this is the custom.hal so far:
net jog-mode <= halui.mode.is-manual
net yen-out yen.out => axis.1.jog-enable
net zen-out zen.out => axis.2.jog-enable
setp axis.0.jog-vel-mode 0
net x-jog-counter <= hm2_5i25.0.encoder.01.count
net x-jog-counter => axis.0.jog-counts
setp axis.0.jog-vel-mode true
setp axis.0.jog-scale 0.000984
setp axis.1.jog-vel-mode 0
net y-jog-counter <= hm2_5i25.0.encoder.02.count
net y-jog-counter => axis.1.jog-counts
setp axis.1.jog-vel-mode true
setp axis.1.jog-scale 0.000984
setp axis.2.jog-vel-mode 0
net z-jog-counter <= hm2_5i25.0.encoder.03.count
net z-jog-counter => axis.2.jog-counts
setp axis.2.jog-vel-mode true
setp axis.2.jog-scale 0.000984
This all works fine.
Now. Also is it beneficial to set the mpg encoder to "times 4 mode" I notice that the mpg turned very slowly each click give me 4 values.
And should I add a low-pass filter component in series with the jog count. if so how?
- Clive S
21 May 2018 08:36 #110949
by Clive S
My mpg's are working now with the custom.hal attached.
Is it beneficial to set the mpg encoder to "times 4 mode" I notice that the mpg turned very slowly each click give me 4 values.
Should I add a low-pass filter component in series with the jog count. if so how? so that it smooths out the indent click on the mpg
- Clive S
21 May 2018 14:13 #110962
by Clive S
Ok update now I seem to have the ilowpass working.
But still need to figure out if I need to set the mpg encoder to "times 4 mode" if so what benefit would it bring.
22 May 2018 06:42 #111018
Clive, my MPG is set up like this
I wonder if you are going 4000 times slower than I am?
I never did get the ilowpass working so I'll be reviewing your hal file...
# --- 7i76e ENCODER SETUP ---
setp hm2_7i76e.0.encoder.00.scale -1
setp hm2_7i76e.0.encoder.00.counter-mode 1I wonder if you are going 4000 times slower than I am?
- Clive S
22 May 2018 11:00 #111026
by Clive S
Rod. Not sure what you mean by "4000 times slower" are you referring to my spindle encoder?
Regarding the ilowpass I have now done some tests and it is working as it should I believe.
This is the relevant bit:-
# X MPG ilowpass
setp ilowpass.mpgX.scale 10 ### this is is multiplied by the "setp axis.0.jog-scale 0.0000492"
setp ilowpass.mpgX.gain 0.01 ### The gain I believe has to be between 0-1
net x-jog-counter => ilowpass.mpgX.in
net ilowpass-0-out ilowpass.mpgX.out
net ilowpass-0-out => axis.0.jog-counts
setp axis.0.jog-scale 0.0000492 ### this give me 5mm travel for one complete turn of the mpg 100 clicks.
By adjusting the gain above certainly smooths out the jog click on the mpg.
Q. I still can not find the answer as to whether (or if I need to) use the "times 4 mode" or is this just for software encoding?
# --- 7i76e ENCODER SETUP --- setp hm2_7i76e.0.encoder.00.scale -1 setp hm2_7i76e.0.encoder.00.counter-mode 1
# X MPG ilowpass
22 May 2018 12:00 #111027
I did try ilowpass and ended up with 1 click on the MPG being 1 metre based on the example in the docs which was not pretty when I used to getting 1mm per click! So I took it out!
What a Crash!!!!!
I did eventually work out I had to change a scale somewhere else when adding in the ilowpass so I've been meaning to try again but I'm off to a conference for 3 days.
I still don't quite understand why you are using such strange values for axis.0.jog-scale because mine is set in device units. My MPG scale is marked x1, x10, x100 so it was a bit unintuitive to me because on the advice of a mate x1 = .01mm, x10 = 0.10mm, x100 = 1mm of movement, so I had to change the scale selections around to match.
Time to create page: 0.158 seconds
