Adding a Mpg to a 7i85s
01 May 2018 14:22 #109908 by Clive S
Replied by Clive S on topic Adding a Mpg to a 7i85s
What more info do I need to provide as I am going around in circles:( . Any help would be appreciated.
01 May 2018 14:57 #109911 by PCW
Replied by PCW on topic Adding a Mpg to a 7i85s
If you have already set this up on a 7I76 this should be nearly the same except for
specific pin and parameter names.
Where are you stuck?
01 May 2018 16:00 #109921 by Clive S
This is what I have in custom hal:
net x-jog-count axis.0.jog-counts
net x-jog-count hm2_5i25.0.encoder.01.count
setp axis.0.jog-enable true
hm2_5i25.0.encoder.01.count counts up and down in blocks of 4
hm2xxxxxxxxxx.input-a goes true and false
hm2xxxxxxxxxxx.position counts up and down
hm2xxxxxxxxxxxxx.vel seems ok up and down
I want to use 3 mpg's one for each axis
File Name: Showpin.txt
File Size:18 KB
Attachment not found
File Name: custom_enc...5-01.hal
File Size:1 KB
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
01 May 2018 21:37 #109950 by rodw
Replied by rodw on topic Adding a Mpg to a 7i85s
Beecause PCW said its similar. From my build thread for a 7i76e (single axis with scale switch)
forum.linuxcnc.org/show-your-stuff/32029...utter-build?start=20
# Metric units used
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=5  sserial_port_0=2xxxx"
loadrt mux4 count=1
addf mux4.0 servo-thread
loadrt or2 count=4
addf or2.3  servo-thread
setp axis.x.jog-vel-mode 0
net x-jog-counter <=  hm2_7i76e.0.7i76.0.0.enc0.count
net x-jog-counter => axis.x.jog-counts
net mux-in1 or2.3.in0 <= hm2_7i76e.0.7i76.0.0.input-22 => mux4.0.sel0
net mux-in2 or2.3.in1 <= hm2_7i76e.0.7i76.0.0.input-21 => mux4.0.sel1
net x-jog-enable <= or2.3.out
net x-jog-enable => axis.x.jog-enable
setp mux4.0.in0 0.0
setp mux4.0.in1 1.0
setp mux4.0.in2 0.1
setp mux4.0.in3 0.01
net x-jog-scale mux4.0.out => axis.x.jog-scale
02 May 2018 12:09 #110014 by Clive S
@Rod
Thanks for the help Rod I had seen this from your build.
Would you mind showing me the code without the scale switch as I only require one scale ie about 0.1
I am have trouble sorting what each line does.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
02 May 2018 13:08 #110018 by rodw
@Rod
Its pretty well documented in my thread piece by piece. The mux4 does the selection so the scale you select is set in the very last line based on the switch position. You could probably use setp to set the value on that line to the scale you want.
The or2 enables the jog wheel only when the scale switch is not set to position 0.
02 May 2018 16:22 - 04 May 2018 07:42 #110034 by Clive S
Almost success :) Thanks to all for helping.
Just looking at X axis first (I have Y & Z working with the same prob) this in custom hal:-
setp axis.0.jog-vel-mode 0
net x-jog-counter <= hm2_5i25.0.encoder.01.count
net x-jog-counter => axis.0.jog-counts
setp axis.0.jog-vel-mode true
#setp axis.0.jog-enable true
setp axis.0.jog-scale 0.000984
BUT I can't set "setp axis.0.jog-enable true" because this is what is reported "halcmd: setp axis.0.jog-enable true
<stdin>:3: pin 'axis.0.jog-enable' is connected to a signal"
I can see that here:-
1988 s32 IN 0 axis.0.jog-counts <== x-jog-counter
1988 bit IN FALSE axis.0.jog-enable <== sxp.xen-button
1988 float IN 0.000984 axis.0.jog-scale
1988 bit IN TRUE axis.0.jog-vel-mode
I can make "axis.0.jog-enable true" by pressing the shuttle express X button on the pendant.
In this case the MPG and pendant works fine.
So problem is how do I solve this so that I can use the MPG without selecting the axis button on the pendant. So that I can have 3 MPG's to use the mill manually.
Last edit: 04 May 2018 07:42 by Clive S.
04 May 2018 07:46 #110173 by Clive S
Any help with the above would be appreciated.
Also is it beneficial to set the mpg encoder to "times 4 mode"
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
04 May 2018 08:35 #110176 by rodw
I think you will find that somewhere you have connected axis.0.jog-enable to a pin on your pendant.
Try
unlinkp axis.0.jog-enable
If it makes you feel better, my commercial pendant has a safety switch that must be pressed before the jog wheel is enabled.
04 May 2018 08:54 - 04 May 2018 08:57 #110179 by Clive S
What I am trying to achieve is to keep the pendant connected all the time but be able to use the 3 mpg's as manual jog wheels for each axis.
The code above lets me only use an mpg when the button on the pendant is activated (ie there is one button for each axis). This means that I cannot use 2 mpg's at the same time.
this is where I think my problem is:
I need to be able to set all the axis.0.jog-enable true, but the button on the pendant is doing that with this ;- 1988 bit IN FALSE axis.0.jog-enable <== sxp.xen-button. Unplugging the pendant does not help either.
I am not sure what info is needed to do this.
Last edit: 04 May 2018 08:57 by Clive S.
Time to create page: 1.359 seconds
