FPGA (field programmable gate array) programmed for linuxcnc motion
8 years 3 months ago - 8 years 3 months ago #114146 by Grotius
Hi Rodw,
Solution was to change L20 to L2.....
Pff.... very simple....
The bad way :
The good way :
For interest, i add the program code. This is done by sheetcam modified postprocessor.
It looks very difficult related to mach3 code.
N0010 (Filename: 1e test ultracut.ngc) N0020 (Post processor: LinuxCNC plasma - laser.scpost) N0030 (Date: 05/28/2018) N0040 G21 (Units: Metric) N0050 G40 G90 N0060 F1 S1 N0070 G40 G64 P0.005 (machine follow path accuracy) N0080 M52 P1 (turn on adaptive feed) N0090 (Part: 1e test ultracut) N0100 (Operation: Outside Offset, 0, T3: plasma 0.95mm ) N0110 G00 Z10.0000 N0120 X68.2435 Y64.4213 N0130 Z3.0000 N0140 S45 N0150 G38.3 Z-100 F500 (height measuring with probe) N0160 G10 L2 P1 Z-10 (correction to z height value) N0170 G0 Z0 F500 (goto z start position) N0180 M03 M65 P1 (M65 = turn off digital output P1 => output 1) N0190 M66 P0 L3 Q5 (Q = wait for arc on => motion digital in) N0200 G04 P0.5 N0210 G01 Z0.0000 F750 N0220 Y62.4213 F3000 N0230 G03 X68.2435 Y62.4213 I0.0000 J14.5250 F3000.0 N0240 G01 Y63.4213 F3000 N0250 M05 M64 P1 (M64 = turn on digital output 1 => remove offsets) N0260 G00 Z10.0000 N0270 X21.6174 Y77.7952 N0280 Z3.0000 N0290 G38.3 Z-100 F500 (height measuring with probe) N0300 G10 L2 P1 Z-10 (correction to z height value) N0310 G0 Z0 F500 (goto z start position) N0320 M03 M65 P1 (M65 = turn off digital output P1 => output 1) N0330 M66 P0 L3 Q5 (Q = wait for arc on => motion digital in) N0340 G04 P0.5 N0350 G01 Z0.0000 F750 N0360 Y75.7952 F3000 N0370 G03 X21.6174 Y75.7952 I0.0000 J2.0250 F3000.0 N0380 G01 Y76.7952 F3000 N0390 M05 M64 P1 (M64 = turn on digital output 1 => remove offsets) N0400 G00 Z10.0000 N0410 X34.6832 Y10.5482 N0420 Z3.0000 N0430 G38.3 Z-100 F500 (height measuring with probe) N0440 G10 L2 P1 Z-10 (correction to z height value) N0450 G0 Z0 F500 (goto z start position) N0460 M03 M65 P1 (M65 = turn off digital output P1 => output 1) N0470 M66 P0 L3 Q5 (Q = wait for arc on => motion digital in) N0480 G04 P0.5 N0490 G01 Z0.0000 F750 N0500 Y8.5482 F3000 N0510 G03 X34.6832 Y8.5482 I0.0000 J24.5250 F3000.0 N0520 G01 Y9.5482 F3000 N0530 M05 M64 P1 (M64 = turn on digital output 1 => remove offsets) N0540 G00 Z10.0000 N0550 X102.4750 Y90.0000 N0560 Z3.0000 N0570 G38.3 Z-100 F500 (height measuring with probe) N0580 G10 L2 P1 Z-10 (correction to z height value) N0590 G0 Z0 F500 (goto z start position) N0600 M03 M65 P1 (M65 = turn off digital output P1 => output 1) N0610 M66 P0 L3 Q5 (Q = wait for arc on => motion digital in) N0620 G04 P0.5 N0630 G01 Z0.0000 F750 N0640 X100.4750 F3000 N0650 Y10.0000 N0660 G02 X90.0000 Y-0.4750 I-10.4750 J0.0000 F3000.0 N0670 G01 X0.0000 F3000 N0680 G02 X-0.4750 Y0.0000 I0.0000 J0.4750 F3000.0 N0690 G01 Y90.0000 F3000 N0700 G02 X10.0000 Y100.4750 I10.4750 J0.0000 F3000.0 N0710 G01 X90.0000 F3000 N0720 G02 X100.4750 Y90.0000 I0.0000 J-10.4750 F3000.0 N0730 G01 X101.4750 F3000 N0740 M05 M64 P1 (M64 = turn on digital output 1 => remove offsets) N0750 G00 Z10.0000 N0760 M52 P0 (stop adaptive) N0770 M05 M30 (program end)
This is the sheetcam postprocessor i used, just for information. There are a few modifications i did to get things
better working.
function OnAbout(event) ctrl = event:GetTextCtrl() ctrl:AppendText("Grotius CNC Machines : plasma and laser post processor\n") ctrl:AppendText("\n") ctrl:AppendText("Modal G-codes and coordinates\n") ctrl:AppendText("Comments enclosed with ( and )\n") ctrl:AppendText("Incremental IJ\n") ctrl:AppendText("Laser outputs power as spindle speed\n") end -- made 23-5-2018 function OnInit() post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text post.Text (" (Filename: ", fileName, ")\n") post.Text (" (Post processor: ", postName, ")\n") post.Text (" (Date: ", date, ")\n") if(scale == metric) then post.Text (" G21 (Units: Metric)\n") --metric mode else post.Text (" G20 (Units: Inches)\n") --inch mode end post.Text (" G40 G90\n F1 S1\n") post.Text (" G40 G64 P0.005 (machine follow path accuracy) \n") post.Text (" M52 P1 (turn on adaptive feed)\n") bigArcs = 1 --stitch arc segments together minArcSize = 0.05 --arcs smaller than this are converted to moves end function OnNewLine() post.Text ("N") post.Number (lineNumber, "0000") lineNumber = lineNumber + 10 end function OnFinish() post.Text (" M52 P0 (stop adaptive)\n") post.Text (" M05 M30 (program end)\n") end function OnRapid() post.ModalText (" G00") post.ModalNumber (" X", endX * scale, "0.0000") post.ModalNumber (" Y", endY * scale, "0.0000") post.ModalNumber (" Z", (endZ + toolOffset) * scale, "0.0000") post.Eol() end function OnMove() post.ModalText (" G01") post.ModalNumber (" X", endX * scale, "0.0000") post.ModalNumber (" Y", endY * scale, "0.0000") post.ModalNumber (" Z", (endZ + toolOffset) * scale, "0.0000") post.ModalNumber (" F", feedRate * scale, "0.###") if(toolType == 8 or toolType == 9) then post.ModalNumber (" S", power, "0.###") end post.Eol() end function OnArc() if(arcAngle <0) then post.ModalText (" G03") else post.ModalText (" G02") end post.NonModalNumber (" X", endX * scale, "0.0000") post.NonModalNumber (" Y", endY * scale, "0.0000") post.ModalNumber (" Z", (endZ + toolOffset) * scale, "0.0000") post.Text (" I") post.Number ((arcCentreX - currentX) * scale, "0.0000") post.Text (" J") post.Number ((arcCentreY - currentY) * scale, "0.0000") post.ModalNumber (" F", feedRate * scale, "0.0###") post.Eol() end function OnPenDown() if (preheat > 0.001) then post.ModalText (" G00") post.ModalNumber (" Z", cutHeight * scale, "0.0000") post.Text ("\n G04 P") post.Number (preheat,"0.###") post.Eol() end post.ModalText (" G00") post.ModalNumber (" Z", pierceHeight * scale, "0.0000") post.ModalNumber (" S", power, "0.###") post.Text ("\n G38.3 Z-100 F500 (height measuring with probe)\n") post.Text ("\n G10 L20 P1 Z-10 (correction to z height value)\n") post.Text ("\n G0 Z0 F500 (goto z start position)\n") post.Text ("\n M03 M65 P1 (M65 = turn off digital output P1 => output 1)\n") post.Text ("\n M66 P0 L3 Q5 (Q = wait for arc on => motion digital in)\n") if (pierceDelay > 0.001) then post.Text (" G04 P") post.Number (pierceDelay,"0.###") post.Eol() end end function OnPenUp() post.Text (" M05 M64 P1 (M64 = turn on digital output 1 => remove offsets)\n") if (endDelay > 0) then post.Text (" G04 P") post.Number (endDelay,"0.###") post.Eol() end end function OnNewOperation() post.Text (" (Operation: ", operationName, ")\n") end function OnComment() post.Text(" (",commentText,")\n") end function OnNewPart() post.Text(" (Part: ",partName,")\n"); end function OnDrill() OnRapid() OnPenDown() endZ = drillZ OnMove() OnPenUp() endZ = safeZ OnRapid() end
This code solution must be tested on a real plasma machine soon. So it is at this moment this solution is not tested !!!
Next problem is to solve the arc on signal during cutting.
The machine waits at start for arc on ....
This works perfect.
But machine must stop if arc is lost during cutting....
I must find a solution for that....I would like a interrupt poll for this.
Last edit: 8 years 3 months ago by Grotius.
8 years 3 months ago - 8 years 3 months ago #114152 by rodw
Thanks for this. More to understand! I have not selected a coordinate system at all.
Perhaps it is possible to set halui.program-pause when ArcOK is lost when halui.program-is-running. this might need a component to deal with some logic conditions. It would be nice to be able to lift the torch so you can change consumables though.
Yesterday I spent some time looking at kerf crossings.
And a plot of the rate of change of voltage at the kerf cross (volts per second)
Still much more to do as this was at 200 ms per reading from halscope
I tried a 1ms capture from halscope but it had no meaningful data so I will repeat using halsampler which I know will sample the data.
Last edit: 8 years 3 months ago by rodw.
8 years 3 months ago - 8 years 3 months ago #114164 by Grotius
Hi Rodw,
Do you have problem's with kerf krossing during cutting? I usually tune the thc speed down that it can do kerf crossing
without problem's. In mach3 it is enough to use a thc speed of 35%.
For the solution that stops the movement of machine when plasma arc is lost, i have maybe an idea.
Common used signals :
thcud.arc-ok ( the arc-on signal from torch height control module)
motion.digital−in−00 ( waits only for thcud.arc-ok at plasma start )
halui.spindle.is−on ( tells you the actual status of m3/m5 )
Status g-code signal:
halui.spindle.is−on
inputs :
thcud.enable
thcud.arc-ok
Maybe use this signals combined with a user defined macro and some simple hal logic.
A short g-code example within the external offset branche :
M03 M65 P1 (M65 = turn off digital output P1 => enable offsets)
M66 P0 L3 Q5 (Q = wait for arc on => motion digital in, in this case it waits = Q.. 5 seconds)
M100 P1(enable arc lost signal)
G01 ..... Cutting program
M100 P0 (disable arc lost signal)
Okey i think this user defined macro is important, otherwise the machine don't know when to look at the arc lost signal.
8 years 3 months ago - 8 years 3 months ago #114171 by Grotius
Hi Rodw,
I have a solution that is working for pausing machine when arc transfer is lost. It depends on 4 files.
M100 (remove extension .txt and make executable)
M101
modified THCUD.comp
Postgui.hal ( this is simple : net pause thcud.pause-machine halui.program.pause
The M100 and M101 specifies the cutting path you exactly need in the program to trigger a arc transfer lost.
It begins to trigger after the waiting periode for stable arc.... And it ends at a m5. That was so difficult of this item.
Start triggering after stable arc....
Tjongejonge.... Why is uploading files so difficult here?
added pin in bit arc_control "M100 & M101 linking arc lost";
added pin out bit pause_machine "Pin for pausing";
For the thcud.comp i made a few modifications. Added pin in and pin out. Added
if(torch_on && arc_control && !arc_ok){ // pause machine pause_machine = 1; } if(!torch_on){ // pause machine pause_machine = 0; }
arc_control is the signal for the cutting path between the arc on waiting macro and the end of the cut.
!arc_ok means, no arc okey. The ! sign means it is not true.
Complete code :
component thcud "Torch Height Control Up/Down Input"; description """ Torch Height Control This THC takes either an up or a down input from a THC If enabled and torch is on and X + Y velocity is within tolerance of set speed allow the THC to offset the Z axis as needed to maintain voltage. If enabled and torch is off and the Z axis is moving up remove any correction at a rate not to exceed the rate of movement of the Z axis. If enabled and torch is off and there is no correction pass the Z position and feed back untouched. If not enabled pass the Z position and feed back untouched. Typical Physical Connections using a Parallel Port .br Parallel Pin 12 <= THC controller Plasma Up .br Parallel Pin 13 <= THC controller Plasma Down .br Parallel Pin 15 <= Plasma Torch Arc Ok Signal .br Parallel Pin 16 => Plasma Torch Start Arc Contacts HAL Plasma Connections .br net torch-up thcud.torch-up <= parport.0.pin-12-in .br net torch-down thcud.torch-down <= parport.0.pin-13-in .br net torch-on motion.spindle-on => parport.0.pin-16-out (start the arc) .br net arc-ok thcud.arc-ok <= motion.digital-in-00 <= parport.0.pin-15-in (arc ok signal) HAL Motion Connections .br net requested-vel thcud.requested-vel <= motion.requested-vel .br net current-vel thcud.current-vel <= motion.current-vel Pyvcp Connections In the xml file you need something like: <pyvcp> <checkbutton> <text>"THC Enable"</text> <halpin>"thc-enable"</halpin> </checkbutton> </pyvcp> Connect the Pyvcp pins in the postgui.hal file like this: net thc-enable thcud.enable <= pyvcp.thc-enable """; author "The real John Thornton, i think it is him B) "; license "GPLv2 or greater"; option singleton yes; // Input Pins pin in bit torch_up "Connect to an input pin"; pin in bit torch_down "Connect to input pin"; pin in float current_vel "Connect to motion.current-vel"; pin in float requested_vel "Connect to motion.requested-vel"; pin in bit torch_on "Connect to motion.spindle-on"; pin in bit arc_ok "Arc Ok from Plasma Torch"; pin in bit enable "Enable the THC, if not enabled Z position is passed through"; pin in float z_pos_in "Z Motor Position Command in from axis.n.motor-pos-cmd"; pin in bit arc_control "M100 & M101 linking arc lost"; // Output Pins pin out float z_pos_out "Z Motor Position Command Out"; pin out float z_fb_out "Z Position Feedback to Axis"; pin out float cur_offset "The Current Offset"; pin out bit vel_status "When the THC thinks we are at requested speed"; pin out bit removing_offset "Pin for testing"; pin out bit pause_machine "Pin for pausing"; // Parameters param rw float velocity_tol "The deviation percent from planned velocity"; param rw float correction_vel "The Velocity to move Z to correct"; // Global Variables variable float offset; variable float last_z_in; function _; ;; #include "rtapi_math.h" FUNCTION(_) { if(enable){ if(torch_on && arc_control && !arc_ok){ // pause machine pause_machine = 1; } if(!torch_on){ // pause machine pause_machine = 0; } float min_velocity = requested_vel -(requested_vel*(velocity_tol*0.01)); if(current_vel > 0 && current_vel >= min_velocity){vel_status = 1;} else {vel_status =0;} if(torch_on && arc_ok && vel_status){ // allow correction if(torch_down){ offset -= correction_vel; } if(torch_up){ offset += correction_vel; } last_z_in = 0; } if(!torch_on){ // remove any offset float z_diff; z_diff = z_pos_in - last_z_in; if(z_diff > 0 && offset != 0){ // torch is moving up removing_offset = 1; if(offset > 0){ // positive offset if(offset > z_diff){ // remove some offset -= z_diff; } else {offset = 0;} } if(offset < 0){ // negative offset if(offset < z_diff){ // remove some offset += z_diff; } else {offset = 0;} } } else {removing_offset = 0;} last_z_in = z_pos_in; } z_pos_out = z_pos_in + offset; z_fb_out = z_pos_in; // keep axis motor position fb from being confused } if(!enable){ z_pos_out = z_pos_in; z_fb_out = z_pos_in; // keep axis motor position fb from being confused } }
Compiling thcud.comp : sudo halcompile --install thcud.comp
Rip location : src / hal / components
Orginal location : /usr/lib/linuxcnc/modules/
Don't forget if you have linux rip running .... To overwrite and replace the compiled comp file to the orginal linuxcnc directory B)
Just for fun, to keep everyone here in good shape :
8 years 3 months ago #114202 by rodw
Grotius, thats great you solved that. I have to put all of these pieces together in my config soon.
I think I'll add a post in the plasma section linking to this post as its got some very useful info in it now.
8 years 3 months ago #114206 by cmorley
motion.feed-inhibit may be helpful here - it will stop all motion if set true.
well it won't stop homing and it will finish a thread pass but I'm sure that is fine.
and it can't be inhibited with Gcode file feed-hold can.
Chris M
Time to create page: 0.311 seconds
