- LinuxCNC
- General LinuxCNC Questions
- FPGA (field programmable gate array) programmed for linuxcnc motion
- Thank you received: 4654
17 Jul 2018 12:33 #114372
Replied by andypugh on topic FPGA (field programmable gate array) programmed for linuxcnc motion
The probing in preview problem can be bypassed with a bit of G-code logic.
(Possibly in the preprocessor).
The issue is what value the preview reads as the probe position. You can trap this in the G-code and subsitute a value:
linuxcnc.org/docs/2.7/html/gcode/overvie...ml#_named_parameters
Look at the #<_task> named parameter.
Wapping the probe move in a O100 IF [#<_task> EQ 1] / O100 ENDIF block will skip the probe during preview.
- Thank you received: 4149
17 Jul 2018 13:00 #114377
Replied by rodw on topic FPGA (field programmable gate array) programmed for linuxcnc motion
Andy, thanks so much for our input. I'll try this the first chance I get.
The docs you linked to state:so it makes sense to me.
#<_task> - 1.0 if the executing interpreter instance is part of milltask, 0.0 otherwise. Sometimes it is
necessary to treat this case specially to retain proper preview, for instance when testing the success of a
probe (G38.x) by inspecting #5070, which will always fail in the preview interpreter (e.g. Axis).Please Log in or Create an account to join the conversation.
- LinuxCNC
Time to create page: 0.299 seconds
