how to use motion-logger?
13 Aug 2018 13:31 #116004 by myz
how to use motion-logger? was created by myz
would you tell me?
16 Aug 2018 12:33 #116132 by andypugh
Replied by andypugh on topic how to use motion-logger?
This?
linuxcnc.org/docs/2.7/html/config/python...sitionlogger_tt_type
I think that is all there is.
If you find out more, please tell us and it can be added to the documentation.
The following user(s) said Thank You: myz
19 Aug 2018 16:02 #116321 by myz
Replied by myz on topic how to use motion-logger?
thanks!
21 Mar 2020 06:06 #160964 by Reinhard
Replied by Reinhard on topic how to use motion-logger?
I just discovered motion-logger and tried to use it - but as soon as I start it, axis does not work any more.
So what is the intended use-case?
21 Mar 2020 06:49 #160965 by cmorley
Replied by cmorley on topic how to use motion-logger?
it's used in AXIS , gladevcp, Qt and Gremlin for display of the gcode.
you can run Gremlin independently beside AXIS, so they might be the best to play with.
Cjris
21 Mar 2020 08:19 #160967 by Reinhard
Hi Chris,
thank you for your attention!
I don't refer to the python-code, but the standalone executable from LC.
I start axis and then I start motion-logger with a logfile argument (both from 2.9 rip environment). When motion-logger is started, axis becomes unusable (may be feedback-channel is globbered?).
i.e.: I enable axis after start and issue a home all axis, to be ready to run the interpreter. Then I start motion-logger. When I then press run in axis, I get the error-message, that the axis need to be homed. But I can't do that from axis any more.
I even tried to start motion-logger before starting axis, but that does not work either.
So - what's my error/misunderstanding?
21 Mar 2020 08:26 #160968 by cmorley
Ok what motion-logger are you talking of?
Chris
21 Mar 2020 08:29 #160969 by Reinhard
linuxcnc-dev/src/emc/motion-logger/motion-logger.c
which results in executable:
linuxcnc-dev/bin/motion-logger
21 Mar 2020 08:33 #160970 by cmorley
Have you looked in tests/motion logger?
I'm sue it's mostly used with linuxcnc's run test.
Which I unfortunately know little about.
Chris
21 Mar 2020 08:53 #160971 by Reinhard
Thanks for the hint.
Did not know that.
Kwick search showed success in tests, so I started a complete rebuild.
Don't know, why I run into trouble.
Thank you for your support!
Time to create page: 0.116 seconds
