how to use motion-logger?
21 Mar 2020 12:17 #160982 by Reinhard
Replied by Reinhard on topic how to use motion-logger?
rebuild of LC finished. Output of motion-logger is a bit more than at first try, but stil far from (my) expectations. But I admit, that my expectations may be wrong.
So I recorded 2 variants:
Rec1 shows, how I first start LC and then motion-logger with its output.
Rec2 shows the opposite, first start motion-logger and then LC.
Please note how LC fails in the second recording.
23 Mar 2020 16:09 #161230 by Reinhard
no solution found yet.
So - did I run into some trivial situation, I should know about?
I think, motion-logger should have some output that is in sync with gremlin output, right?
So when I start gcode processing with motion-logger active and gremlin does not work any more, than something must be wrong, isn't it?
Any advices, how to proceed?
24 Mar 2020 16:02 #161355 by Reinhard
Just verified, that my app works fine together with axis - and yes, it runs in sync with axis gremlin and gcode-lister.
So what does motion-logger different, in that it clobbers axis state and functionality?
24 Mar 2020 18:45 #161363 by cmorley
Replied by cmorley on topic how to use motion-logger?
You probably need to inquire on the dev list or IRC.
The devs that would know the most about motion logger don't look at the forum.
Well actually, they hardly involved in linuxcnc anymore.
Chris
25 Mar 2020 02:53 #161391 by Reinhard
Not sure, if I understand it right.
Does it mean, that lc lost its developer?
I follow the changes on master repository and it looks to me, that only plasma and qt is of interest.
So no one is working on python migration and core?
What a mess!
25 Mar 2020 08:05 #161399 by cmorley
Most of the active developers of the past are busy with other things these days.
There are really quite few of active devs with push rights.
So most work is done outside of linuxcnc and its hard to get included in a timely fashion.
There was work on python 3, not sure if it got pushed to linuxcnc test branch or not.
Hopefully things will change for the better.
Chris
25 Mar 2020 13:08 #161424 by Reinhard
Hi Chris,
sad to hear that! But ...
... you said, what I already suspected from the changes at master.
So if the core developers have dedicated themselfs to other doings, the knowledge of core has disappeared with them.
And LC is really very big to get into it :(
25 Mar 2020 13:30 #161427 by cmorley
Oh they are not all completely gone. Ask your question in the IRC yo may get answer.
It's just time to recruit some more interested people and get away from everyone working on outside projects that are all similar and never getting them incorporated We need a leader to start the ball rolling (IMHO)
Chris
25 Mar 2020 14:10 #161430 by Reinhard
... get away from everyone working on outside projects that are all similar and never getting them incorporated
Yes, its a shame - but plenty of them fork by an idea and died without having a leader or at least passion.
Yes, I agree completely.
I saw it in many many projects that claim: we don't want a leader, we don't need a leader ...
They never succeed.
25 Mar 2020 14:23 #161434 by cmorley
A quick look in the run tests (I have to fix one with an update I'm working on), I would bet motion-logger was never meant to run beside the motion component.
both would be trying to be connected to task using shared memory.
They may both use the same shared memory key, or when one connects it locks out the other.
I'm just guesstimating ...
Chris
