how to use motion-logger?
- Reinhard
- Thank you received: 94
I'm digging too
Guess u r right - as both motion and motion-logger clear the shared memory in init_comm_buffers - that can't be sane.
I wonder - as I have a working code for nml-interface. Wouldn't it be possible, read the commands with my code?
Is motion-logger intended to read the same nml-queues than axis or any other lc-part does?
Or does motion have a different (/extended?) shared-memory view?
If it is the known nml queue that axis reads, I will try to read the commands by myself.
- Thank you received: 2181
Thu UIs use NML to talk to Task and Task uses NML to talk to motion or motion-logger
linuxcnc.org/docs/2.8/html/code/code-not...rchitecture_overview
Motion-logger just logs motion commands from Task's motion queue. AFAIK
Which commands do you want to read?
- Reinhard
Well, I appreciate your support!I don't want to talk like I know something here ...
... and your guess is by far more than my knowing nothing ...
Well, that's what motion-logger is supposed to do for the unknown ...Motion-logger just logs motion commands from Task's motion queue. AFAIK
I had to realize, that status channel does not report all states and state changes. Some status messages are out of time or not implemented ...Which commands do you want to read?
When I discovered motion-logger, I had the hope, that it gets rid of ongoing things, I was missing.
My app works fine with the nml-interface of reading status messages and sending commands to lc-server.
Just wanted to get a bit closer to the hearbeat of lc.
... and as you said, that gremlin uses motion-logger as base, may be I could implement some sort of gremlin too? I don't like the idea to reparse the gcode in the UI just for getting gremlin to work.
it logs the tool position so it can plot it. (some how I forget)
It also reads the gcode and converts to OpenGL commands.
It does the gcode parsing when you load the program (that's why long programs can take a while to load)
It's written in C++ but it's a python library.
Can you embed Gremlin?
- Reinhard
Well, I already have the tool position, as I drive dro elementsit logs the tool position so it can plot it. (some how I forget)
That's what I tried to avoid.It also reads the gcode and converts to OpenGL commands.
For me, its dumb, do the same stuff twice in different locations and duplicate code ...
I hoped, that backend would deliver enuf status informations for doing the gremlin stuff.
I dunno - but I guess it would not be possible.Can you embed Gremlin?
But there exists an opengl library for java, so may be I can try it ...
I hoped, that backend would deliver enuf status information for doing the gremlin stuff.
I don't follow . where else is this done?
If you want to see the shape being cut then you must parse the file and convert it to graphics commands.
Chris
- Reinhard
may be I got you wrong.I don't follow . where else is this done?
Backend parses gcode to generate motion commands.
I did understand you that way, that gremlin (foreground ui) parses gcode too to generate graphics commands (that's what I read from other ui programmers too, or at least that's what I thought to understand).
If that is true, for me the parsing happens twice: once in background and once in foreground - and both are of cause separate code domains.
I was speaking about the conversion to openGL commands that happens after that so didn't follow the road there..
A little quote from the remap docs might add some light:
For complete preview of a remapped code’s tool path some precautions need to be taken. To understand what is going on, let’s review the preview and execution process (this covers the Axis case, but others are similar):
First, note that there are two independent interpreter instances involved:
one instance in the milltask program, which executes a program when you hit the Start button, and actually makes the machine move
a second instance in the user interface whose primary purpose is to generate the tool path preview. This one executes a program once it is loaded, but it doesn’t actually cause machine movements.
Now assume that your remap procedure contains a G38 probe operation, for example as part of a tool change with automatic tool length touch off. If the probe fails, that would clearly be an error, so you’d display a message and abort the program.
Now, what about preview of this procedure? At preview time, of course it’s not known whether the probe succeeds or fails - but you would likely want to see what the maximum depth of the probe is, and assume it succeeds and continues execution to preview further movements. Also, there is no point in displaying a probe failed message and aborting during preview.
