stidrvr wrote: I’m just using the touch off option.
I cannot save my tool lengths because the spindle is similar to a router collet setup. So it’s impossible to get repeatable tool lengths.
Then you don't need to use TnM6 at all.
Here's what I do in that case.
After putting the tool in I jog down until I'm close to the top of the material and using a dowel I slowly move up until the dowel just clears under the tool.Then press the "Touch Off" button and enter the diameter of the dowel and your done with Z
Another "trick" I use to set the X0 of the material is to have a dowel in the spindle and with the material loose in the vise I jog up to the side and press the material against the dowel and tighten the vise. Now I Touch off the X axis (make sure X is selected) and enter 1/2 the dowel diameter. If the left side is X0 then do the above on the left side and enter -1/2 the diameter of the dowel.
The rear face of the vise is always my Y0 but that could change depending on the setup.
JT
curtisa wrote: There are ways of getting tool length compensation going in Axis following a manual tool change, but it is a little fiddly.
The way I've done it is to add a touchplate to my mill and remap the M6 command into a subroutine to make Axis measure the length of each tool every time a tool change is performed. Method is outlined here:
forum.linuxcnc.org/forum/10-advanced-con...h-off?start=30#48235
This works even if your collet/tools isn't designed to use preset-height cutters. It just measures the length of each tool and adds or subtracts that offset from the initial touch off.
