FLOAT PIN FOR FOLLOWING ERRORS?
  • COlger81
  • COlger81's Avatar Topic Author
  • Elite Member
  • Elite Member
14 Nov 2018 14:10 #120679 by COlger81
Replied by COlger81 on topic FLOAT PIN FOR FOLLOWING ERRORS?
What following error would you expect to see roughly at 150 IPM from a decent mill? .030" (.762mm) seems pretty extreme and i think i have some tuning to do.
14 Nov 2018 14:24 #120681 by dgarrett
Replied by dgarrett on topic FLOAT PIN FOR FOLLOWING ERRORS?
joint.N.f-error-lim is a hal output pin from the motion module
$ man motion
joint.N.f−error−lim OUT FLOAT
          The following error limit
linuxcnc.org/docs/master/html/man/man9/motion.9.html
Relevant ini settings:
2.13. [JOINT_<num>]Section
MIN_FERROR = 0.010 - This is the value in machine
units by which the axis is permitted to deviate
from commanded position at very low speeds. If
MIN_FERROR is smaller than FERROR, the two produce
a ramp of error trip points. You could think of
this as a graph where one dimension is speed and
the other is permitted following error. As speed
increases the amount of following error also
increases toward the FERROR value.
FERROR = 1.0 - FERROR is the maximum allowable
following error, in machine units. If the
difference between commanded and sensed position
exceeds this amount, the controller disables servo
calculations, sets all the outputs to 0.0, and
disables the amplifiers. If MIN_FERROR is present
in the .ini file, velocity-proportional following
errors are used. Here, the maximum allowable
following error is proportional to the speed, with
FERROR applying to the rapid rate set by
[TRAJ]MAX_VELOCITY, and proportionally smaller
following errors for slower speeds. The maximum
allowable following error will always be greater
than MIN_FERROR. This prevents small following
errors for stationary axes from inadvertently
aborting motion. Small following errors will
always be present due to vibration, etc.
Ref: linuxcnc.org/docs/master/html/config/ini-config.html
Note: Above docs are for the master branch (2.8~pre)
14 Nov 2018 14:29 #120682 by andypugh
Replied by andypugh on topic FLOAT PIN FOR FOLLOWING ERRORS?
It depends a lot on the machine, and also how the acceleration and velocity limits in the controller compare to the actual physical limits of the machine.
Do you have reason to believe that things were better before switching to 2.8, or had you just not really looked in detail?
(Assuming I have not got my posters mixed up).
What happens if you lower the acceleration limits of the joints, does the f-error reduce?
I-gain might help.
When cruising at high speed and with a large f-error, is the amplifier anywhere near saturated?
  • COlger81
  • Elite Member
  • Elite Member
14 Nov 2018 16:35 #120688 by COlger81
Lowering accelerations had no effect on the following errors. I am using the halscope right now. I think it's just a tuning issue.
  • COlger81
  • Elite Member
  • Elite Member
14 Nov 2018 20:34 #120697 by COlger81
Andy;
I was getting too aggressive on the drives so i changed my plan. I tuned the drives to Fadal manual spec. Now i'm going through PID tuning in software. Halscope looks pretty linear as far as following errors go. I just need to stiffen them up to reduce following errors. Any starting suggestions? I lowered max velocity to 30 and I'm at P of 120 currently.
14 Nov 2018 20:54 #120698 by PCW
Replied by PCW on topic FLOAT PIN FOR FOLLOWING ERRORS?
Are the drives running in velocity mode?
If so the main tuning is via FF1
  • COlger81
  • Elite Member
  • Elite Member
14 Nov 2018 21:33 - 14 Nov 2018 21:34 #120703 by COlger81
Yes, they are in velocity mode. I currently have P=400 and FF1=1.152;
2.88volts at 150 ipm
10volts at 520.833
520.833/60=8.681
10/8.681=1.152
Does this look correct?
(I'm getting .007" following error at 150 IPM)
Last edit: 14 Nov 2018 21:34 by COlger81.
14 Nov 2018 21:59 #120704 by PCW
Can you post a halscope plot of following error + commanded velocity?
Note that even if you cannot get the calibrate popup to work,
you can set the PID parameters "live" via halcmd. You can also do this with
halshow, but halcmd is easier since it has the consoles command history and line editing features
  • COlger81
  • Elite Member
  • Elite Member
14 Nov 2018 22:21 #120705 by COlger81
14 Nov 2018 22:33 - 14 Nov 2018 22:39 #120706 by PCW
That looks like almost exclusively FF1 tweaking needed:
( halcmd setp pid.N.ff1 something, make a 10% change, is it better or worse? )
Last edit: 14 Nov 2018 22:39 by PCW.
Time to create page: 0.131 seconds
