FLOAT PIN FOR FOLLOWING ERRORS?
15 Nov 2018 00:29 #120720 by PCW
Replied by PCW on topic FLOAT PIN FOR FOLLOWING ERRORS?
Yes, pncconf does this but it also connects the signals to LinuxCNCs commanded velocity pins (that was the part missing from COlger81's hal file)
You can achieve a similar result by simply disconnecting the PID components command-deriv pins, as the PID component calculates the command derivative itself if its command-deriv pin is not connected.
15 Nov 2018 00:36 #120722 by alan_3301
Replied by alan_3301 on topic FLOAT PIN FOR FOLLOWING ERRORS?
Thanks, maybe Colger81 and I were using pncconf incorrectly.
It put in the net x-vel-cmd => pid.x.command-deriv
But it didn't connect the x-vel-cmd to anywhere else in the hal file.
15 Nov 2018 00:45 #120724 by PCW
Thats probably a bug in pncconf for Servo configs
  • COlger81
  • COlger81's Avatar Topic Author
  • Elite Member
  • Elite Member
15 Nov 2018 03:06 #120730 by COlger81
Replied by COlger81 on topic FLOAT PIN FOR FOLLOWING ERRORS?
Thanks for the help guys. I'm running .0003" or better on all axis at rapid speed.
Time to create page: 0.092 seconds
