Problem with Run
- tfhess
26 Nov 2018 16:35 #121377
by tfhess
Problem with Run was created by tfhess
I am having a problem with "Run" on emc2 version 2.7.0. In short, nothing happens when invoked on Axis (or any other gui)
I have full manual control of my mill, can home axes and move them around but nothing works when trying to run a gcode program, including examples from the .iso build. I am running a pico pwm board with servos on 3-axis mill.
I have attached an .ini file and gcode for more info.
Any advice, suggestions on this problem?
- tim@home
- Thank you received: 3
27 Nov 2018 00:59 #121418
by tim@home
Replied by tim@home on topic Problem with Run
Did you create your ini file with stepconf?
- tfhess
27 Nov 2018 01:45 #121420
by tfhess
Replied by tfhess on topic Problem with Run
No - used a preexisting .ini from Jon Elson and then added to it with editor.
- Thank you received: 7491
27 Nov 2018 06:24 #121452
Replied by tommylight on topic Problem with Run
Do you happen to have "spindle at speed" somewhere in hal?
If you do not have any feedback from the spindle and you have that statement in hal, it will be waiting for that signal so it will not move at all any time it gets the M3 command.
- tfhess
28 Nov 2018 15:39 #121528
by tfhess
Thanks for the suggestion. I did look at the hal files, deleted reference to spindle, but the problem still exists.
Its interesting that example nc files (axis, 3-d chips) do run with spindle calls - but my nc files do not even though they came from mastercam (from an EMC2 post processor). I put a line in [Filter] to recognize them as .NC files.
Today I plan to compare the nc files that do run to mine to look for characters that the interpreter does not like.
- bevins
- Thank you received: 338
28 Nov 2018 15:58 - 28 Nov 2018 16:05 #121529
by bevins
Replied by bevins on topic Problem with Run
Can you upload your .hal file?
Also, start linuxcnc from a console and see if it spits anything pertinent.
Try entering T1 M6 in the MDI window? any reaction?
Last edit: 28 Nov 2018 16:05 by bevins.
- tfhess
28 Nov 2018 17:54 #121534
by tfhess
A ha. There was trouble with the T1 M3 statement. Wouldn't run in MDI window - just froze up for a bit. When I took that statement out of my NC file, it ran as normal.
So my run problem is solved for the short term (thanks for the suggestion!), but what is going on with loading a tool? The tool table feature has never worked.
- bevins
28 Nov 2018 18:07 #121536
by bevins
Last I checked it is a T1 M6 statement.
A ha. There was trouble with the T1 M3 statement. .
- tfhess
28 Nov 2018 18:35 #121539
by tfhess
Yeah, typo on my part.
30 Nov 2018 15:41 #121637
Replied by andypugh on topic Problem with Run
It sounds like a problem with the tool-change loop.
T1 sets iocontrol.0.tool-prepare true, and waits (indefinitely) for iocontrol.0.tool-prepared to go true. Often these are just connected together:Then the M6 sets iocontrol.0.tool-change and waits for iocontrol.0.tool-changed.
Often those are looped together too, but more frequently they pass through hal_manualtoolchange to force an on-screen prompt.
If either loop is left open then things will stop during a tool change request.
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-preparedOften those are looped together too, but more frequently they pass through hal_manualtoolchange to force an on-screen prompt.
The following user(s) said Thank You: tfhess
Time to create page: 0.116 seconds
