Problem with Run
- tfhess
30 Nov 2018 19:22 #121645
by tfhess
Replied by tfhess on topic Problem with Run
Thanks Andy.
I took a look at my axis_manualtoolchange.hal file (attached) to see if it seemed correct in light of your message. Not being a programmer, I don't really know if it is.
What I do know is that when I ran a program with T1M6 in it, I expected a dialog box to pop up and give me a chance to change/insert a tool, hit ok and continue run. It never happened (program went to never never land and with no way to get out of it, stayed there). I suspect that the real culprit is no hal pin connected the manual tool change feature. My fault in using a canned .ini file from Jon Elson and not setting up the tool change feature.
- Thank you received: 4652
30 Nov 2018 20:14 #121647
Replied by andypugh on topic Problem with Run
That looks OK. The next question is whether that file (axis_manualtoolchange.hal) is called out in the INI file [HAL] section.
(And how about tool-prepare?)
- tfhess
30 Nov 2018 20:27 #121649
by tfhess
My .ini (attached) does not appear to have a call for manual tool change nor tool prep.
If you wouldn't mind, what should the additional code lines look like?
30 Nov 2018 20:31 #121650
in the [HAL] section of the INI
HALFILE = axis_manualtoolchange.halPlease Log in or Create an account to join the conversation.
- Thank you received: 1472
30 Nov 2018 20:37 - 30 Nov 2018 20:39 #121651
Replied by Todd Zuercher on topic Problem with Run
You aren't referencing the axis_manualtoolchange.hal file in your ini file.
You would need to add the lineto the [HAL] section of your ini file for axis_manualtoolchange.hal to have any effect on your configuration.
Last edit: 30 Nov 2018 20:39 by Todd Zuercher.
- tfhess
30 Nov 2018 22:50 #121657
by tfhess
Todd and Andy:
Thanks for the suggestion. I added to .ini but that did not solve the run problem. A dialog box does pop up when emc2 starts (references tool change, how you can resize the box etc., and disappears shortly after) but the dialog for a tool change never appears when running a g-code program. "Run" obviously then does not operate.
Is there something else missing in the .ini?
- MaHa
- Thank you received: 240
30 Nov 2018 23:38 #121659
by MaHa
Replied by MaHa on topic Problem with Run
I compared your manualtoolchange.hal with my old parallelport config. The commands in my working file are in opposite order. I don't know if this matters. Just an idea
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
- tfhess
01 Dec 2018 02:12 #121666
by tfhess
Great! Thanks. I will try your version tomorrow.
- tfhess
01 Dec 2018 21:35 #121692
by tfhess
I tried your version of the tool change file, but it did not change the emc2 behavior from the previous tool file. Still no tool popup window when the g code had a T1M6 call and Run did not work correctly. There must be something else I am missing.
No big problem on g code with only 1 tool. Just remove the T1M6 call from the g code and everything runs fine.
02 Dec 2018 12:19 #121709
So, how is your HAL connected?
This really shouldn't be complicated, it is only 4 HAL pins and two of those simply need to be connected together.
With LinuxCNC idle, can you have a look in the "Machine->Show HAL configuration" dialog and see where iocontrol.0.tool-prepare / prepared and iocontrol.0.tool-change / changed are connected?
You might need to look in both the "pins" and "signals" sections.
Then add the 4 pins to a "Watch" tab, MDI a tool change request and watch what happens.
Time to create page: 0.157 seconds
