Finished parts ending like they were offset some how...
29 Dec 2018 03:57 #123050 by Leon82
Double Check the coupler between the motor and ball screw
  • Moderator
  • Moderator
29 Dec 2018 07:13 #123056 by tommylight
That looks like you have active offsets.
  • Marcking
  • Marcking's Avatar Topic Author
  • Junior Member
  • Junior Member
29 Dec 2018 12:18 - 29 Dec 2018 12:22 #123068 by Marcking
Thank you tommylight, there is G40 on, there is another offset we need to turn off?
Also tool compensation usually does not move to one side only, G41/G42 would left a part that could be smaller or bigger but not shifted, I think...
Last edit: 29 Dec 2018 12:22 by Marcking.
  • Marcking
  • Junior Member
  • Junior Member
29 Dec 2018 12:24 #123069 by Marcking
Leon82, do you think mechanical play could be reflected on the graphic screen? besides machine mechanics has been verified.
Thanks.
29 Dec 2018 13:50 #123073 by Leon82
Thanks.
I'm not sure I kind of responded before realizing there was 3 pages of discussion
  • Marcking
  • Junior Member
  • Junior Member
29 Dec 2018 16:26 #123101 by Marcking
Ha ha ha, there is another subject on discussion anyway.
Thank you for enter the topic.
31 Dec 2018 13:27 #123201 by andypugh
Possibly stray XY tool offsets in the tool table? Typically a mill would never use the XY columns.
  • Marcking
  • Junior Member
  • Junior Member
31 Dec 2018 15:10 #123213 by Marcking
Hi Andy, we are using the gmoccapy screen and not using tool compensation at all G40 is at the beginning of the program.
31 Dec 2018 15:52 #123216 by andypugh
I am talking about tool offset, not compensation.
Tools can have lengths in all axes, not just Z.
  • Marcking
  • Junior Member
  • Junior Member
31 Dec 2018 16:29 #123220 by Marcking
sure they do!, but only using G41/G42 they use radius or diameter compensation, also as stated before part will end up bigger or smaller not shifted.
Time to create page: 0.204 seconds
