ESCape key issues in Pre1-4587 build ???
7 years 8 months ago #127411 by shipmodeller
Since I am a user of LinuxCNC, not a programmer of it.. I have no idea how to do this check. I'd be happy to post whatever you want.. Just tell me the files and I'll post. Thanks. ( Other than some subroutines changes, I have not altered any LinuxCNC config file, except for one HAL file under the direction of andypugh. from the previous full release to this one. )
7 years 8 months ago - 7 years 8 months ago #127413 by shipmodeller
BTW: My CAM program is MasterCam X5, I haven't updated it in years. I did modify the post long time ago from driving my Tormach PCN1100 machine based on Mach 3 to the new Wood Router using LinuxCNC. If anyone has a true post file for MasterCam X5 to properly drive Gcode for LinuxCNC, I am more than happy to try it. Thanks.
Last edit: 7 years 8 months ago by shipmodeller. Reason: typo
7 years 8 months ago #127422 by Leon82
Mpfan should be close enough for Linux cnc.
7 years 8 months ago #127437 by tommylight
andypugh wrote: Before we go off on weird tangents, is anyone else running this version of LinuxCNC and can check that ESC only stops the program and does not turn the machine off?
Sorry but i am using a version with reverse run and external offsets testing the PhillC's configuration for plasma and THC. It just says Pre1 !!! Is there any other way i can find out what build it is?
7 years 7 months ago #127639 by andypugh
I just tried an experiment with an up-to-date build of LinuxCNC and can not reproduce the problem.
So, it seems that it might be specific to your setup.
Can you try running one of the sim configs (I used sim/axis/axis_mm) and see if you also see the problem there?
The following user(s) said Thank You: shipmodeller
7 years 7 months ago - 7 years 7 months ago #127707 by shipmodeller
LinuxCNC emulator works perfectly. Does not knock machine off.
Last edit: 7 years 7 months ago by shipmodeller. Reason: Went to shop this morning
Time to create page: 0.071 seconds
