ESCape key issues in Pre1-4587 build ???
- shipmodeller
- Thank you received: 3
25 Feb 2019 23:20 #127132
by shipmodeller
ESCape key issues in Pre1-4587 build ??? was created by shipmodeller
Since the new build got installed.. the ESCape key doesn't seem to function correctly.
If in the middle of a job, you hit the ESC key to terminate it, for a problem ( And boy, do I have problems... ) The system stops immediately. Great! BUT... the manual keys are disabled.. you cannot move the Z axis up or down with the PgUp or PgDn keys, and you cannot move the X or Y axis using the arrow keys.
In order to restore operation, I had to exit LinuxCNC, then reload it. Once I did that, and then hit the X button and enabled the machine.. I can then use the arrow keys. This did not appear to be an issue in previous builds.. but to be honest, it has been one or two builds ago that I last used the esc to prevent my bit from killing itself.
- Thank you received: 2175
26 Feb 2019 09:03 #127145
Replied by cmorley on topic ESCape key issues in Pre1-4587 build ???
What screen are you using?
Chris
Chris
- shipmodeller
26 Feb 2019 16:53 #127172
by shipmodeller
Replied by shipmodeller on topic ESCape key issues in Pre1-4587 build ???
?? Axis Screen ?? You may need to be more specific to How to Tell you what screen I am using. Please remember that some of us just like to install and use the software. I have an RS485 controlled spindle, two parallel ports. Problem seems to happen when the machine is driving spindle and going into piece.
- Thank you received: 1472
26 Feb 2019 17:27 #127174
Replied by Todd Zuercher on topic ESCape key issues in Pre1-4587 build ???
He was asking which user interface are you using, Axis, Gmoccapy. ..
The following user(s) said Thank You: shipmodeller
- shipmodeller
26 Feb 2019 17:51 #127175
by shipmodeller
Axis ..
- Thank you received: 4652
26 Feb 2019 22:59 #127211
Replied by andypugh on topic ESCape key issues in Pre1-4587 build ???
Is it just that the MDI tab rather than manual tab is active?
Manual jog keys only work with the manual tab showing.
- shipmodeller
27 Feb 2019 00:27 #127215
by shipmodeller
No, the MDI tab was not active. I was in the middle of a run, so I had pressed the R key to run the program.. after that, I do not touch the interface again till the job stops. I have been using LinuxCNC for a few years now, and it's possible I could have made a rookie mistake like that ... but no, it was not in the MDI tab mode.
It was either going into the wood or close to that when I hit the ESC key, stopping the spindle and motion. When I tried to use the PG UP key, nothing happened. None of the other keys worked until I rebooted.
- Thank you received: 7471
27 Feb 2019 07:56 #127225
Replied by tommylight on topic ESCape key issues in Pre1-4587 build ???
Are you using parallel port ?
That behaviour is indicative of interference to the parallel port, you should check the grounding and shielding.
27 Feb 2019 09:58 #127229
Another possibility is if you have a GladeVCP tab open. If the mouse cursor is over the GladeVCP then that grabs the keyboard events.
This used to drive me mad on my old Axis lathe, but an MPG works better than the keyboard in every way and is a complete fix
No, the MDI tab was not active. I was in the middle of a run, so I had pressed the R key to run the program.. after that, I do not touch the interface again till the job stops..
The following user(s) said Thank You: Leon82
- Leon82
- Thank you received: 79
27 Feb 2019 12:12 #127240
by Leon82
Replied by Leon82 on topic ESCape key issues in Pre1-4587 build ???
I've noticed If you click off the window, like the desktop it won't respond to keyboard shortcuts either
Time to create page: 0.532 seconds
