ESCape key issues in Pre1-4587 build ???
- Thank you received: 7488
27 Feb 2019 14:02 #127246
Replied by tommylight on topic ESCape key issues in Pre1-4587 build ???
Just read the thread again, you are using parallel ports, and that is for sure interference from the spindle due to lack of shielding or proper grounding.
- shipmodeller
- Thank you received: 3
27 Feb 2019 17:42 #127273
by shipmodeller
Replied by shipmodeller on topic ESCape key issues in Pre1-4587 build ???
Machine has been running for quite sometime now, it may, MAY be possible that you are correct. However, with the previous versions, I never had this issue.. and my finger is quite fast hitting the ESC key ( or the emergency stop.. ) Never experienced this problem. With the latest install of LinuxCNC, I have been experiencing this issue, with no hardware changes in the last year ...
So, ok.. perhaps this thread can be terminated.. I will be very careful watching and documenting. If I experience this issue again, I hope to have some better, repeatable steps. I wish I knew which or where the logs were so I can post them as well. Already have two issues dealing with subroutines in the queue to be resolved, thought this might be seen by others.. so ... we'll just wait and see if I can document this better.
Thanks for all the posts.
- shipmodeller
01 Mar 2019 00:16 #127373
by shipmodeller
Ok.. it happened yet again today. This time I was a bit more observant.
1: It was executing the following line
N150 G0 G90 X-.228 Y-3.9899
2: I hit the ESC button to stop it.. it still took out my wood.
3: Hitting the PG-UP button didn't do anything , except .. I got the following error that I had not noted before
ERROR: Can't do that ( EMC_TASK_PLAN_RUN) in Auto mode with the interpreter waiting.
I also think I noted that the ESC key took the Machine power button to off???
After I toggled the Power Button on the Axis gui, the PG UP and all the other buttons seem to work.
So.. is this the expected behavior? I don't remember it doing this before this release, but I could be wrong...
01 Mar 2019 00:48 #127375
That is gcode made for Mach3, right ?
I would advise not to use gcode made for mach as i am sure there are differences in what certain Gxx does.
And once more, ground your spindle, properly. And the electronics side.
The following user(s) said Thank You: shipmodeller
- shipmodeller
01 Mar 2019 01:00 #127377
by shipmodeller
Well, no... this was Gcode made for LinuxCNC Gcode .. not Mach3.
I have been running these codes for eons, and are standard GCODE's . If LinuxCNC stops supporting these, well.. I'll be ...
In question is not the Gcode, but the action of the ESC key. As an engineer and programmer for 53 years, I am very strict on grounding issues. Machine is well grounded. Shielded cables,... the ESC key is the question.
01 Mar 2019 01:39 #127381
I have seen that kind of behaviour only on plasma arc start on machines that had lousy grounding or none at all, using parallel ports.
I have also seen something worse than that regarding ESC key on EdingCNC ( formerly USBCNC ), when hitting the ESC key it would say FIFO underrun and shut down completely !!! Always!
- MaHa
- Thank you received: 241
01 Mar 2019 10:15 #127393
by MaHa
Replied by MaHa on topic ESCape key issues in Pre1-4587 build ???
Did you check the keyboard properties, or the keycode, scancode of the esc key?
01 Mar 2019 10:36 #127396
Replied by andypugh on topic ESCape key issues in Pre1-4587 build ???
Before we go off on weird tangents, is anyone else running this version of LinuxCNC and can check that ESC only stops the program and does not turn the machine off?
I am pretty sure that it just stops the current G-code, but won't be near a LinuxCNC machine again until sunday evening at the earliest.
- shipmodeller
01 Mar 2019 13:17 #127411
by shipmodeller
Since I am a user of LinuxCNC, not a programmer of it.. I have no idea how to do this check. I'd be happy to post whatever you want.. Just tell me the files and I'll post. Thanks. ( Other than some subroutines changes, I have not altered any LinuxCNC config file, except for one HAL file under the direction of andypugh. from the previous full release to this one. )
- shipmodeller
01 Mar 2019 13:20 - 01 Mar 2019 13:27 #127413
by shipmodeller
BTW: My CAM program is MasterCam X5, I haven't updated it in years. I did modify the post long time ago from driving my Tormach PCN1100 machine based on Mach 3 to the new Wood Router using LinuxCNC. If anyone has a true post file for MasterCam X5 to properly drive Gcode for LinuxCNC, I am more than happy to try it. Thanks.
Last edit: 01 Mar 2019 13:27 by shipmodeller. Reason: typo
Time to create page: 0.529 seconds
