ESCape key issues in Pre1-4587 build ???
  • shipmodeller
  • shipmodeller's Avatar Topic Author
  • Senior Member
  • Senior Member
25 Feb 2019 23:20 #127132 by shipmodeller
ESCape key issues in Pre1-4587 build ??? was created by shipmodeller
Since the new build got installed.. the ESCape key doesn't seem to function correctly.
If in the middle of a job, you hit the ESC key to terminate it, for a problem ( And boy, do I have problems... ) The system stops immediately. Great! BUT... the manual keys are disabled.. you cannot move the Z axis up or down with the PgUp or PgDn keys, and you cannot move the X or Y axis using the arrow keys.
In order to restore operation, I had to exit LinuxCNC, then reload it. Once I did that, and then hit the X button and enabled the machine.. I can then use the arrow keys. This did not appear to be an issue in previous builds.. but to be honest, it has been one or two builds ago that I last used the esc to prevent my bit from killing itself.
26 Feb 2019 09:03 #127145 by cmorley
Replied by cmorley on topic ESCape key issues in Pre1-4587 build ???
What screen are you using?
Chris
  • shipmodeller
  • Senior Member
  • Senior Member
26 Feb 2019 16:53 #127172 by shipmodeller
Replied by shipmodeller on topic ESCape key issues in Pre1-4587 build ???
?? Axis Screen ?? You may need to be more specific to How to Tell you what screen I am using. Please remember that some of us just like to install and use the software. I have an RS485 controlled spindle, two parallel ports. Problem seems to happen when the machine is driving spindle and going into piece.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
26 Feb 2019 17:27 #127174 by Todd Zuercher
Replied by Todd Zuercher on topic ESCape key issues in Pre1-4587 build ???
He was asking which user interface are you using, Axis, Gmoccapy. ..
The following user(s) said Thank You: shipmodeller
  • shipmodeller
  • Senior Member
  • Senior Member
26 Feb 2019 17:51 #127175 by shipmodeller
Axis ..
26 Feb 2019 22:59 #127211 by andypugh
Replied by andypugh on topic ESCape key issues in Pre1-4587 build ???
Is it just that the MDI tab rather than manual tab is active?
Manual jog keys only work with the manual tab showing.
  • shipmodeller
  • Senior Member
  • Senior Member
27 Feb 2019 00:27 #127215 by shipmodeller
No, the MDI tab was not active. I was in the middle of a run, so I had pressed the R key to run the program.. after that, I do not touch the interface again till the job stops. I have been using LinuxCNC for a few years now, and it's possible I could have made a rookie mistake like that ... but no, it was not in the MDI tab mode.
It was either going into the wood or close to that when I hit the ESC key, stopping the spindle and motion. When I tried to use the PG UP key, nothing happened. None of the other keys worked until I rebooted.
  • Moderator
  • Moderator
27 Feb 2019 07:56 #127225 by tommylight
Replied by tommylight on topic ESCape key issues in Pre1-4587 build ???
Are you using parallel port ?
That behaviour is indicative of interference to the parallel port, you should check the grounding and shielding.
27 Feb 2019 09:58 #127229 by andypugh
No, the MDI tab was not active. I was in the middle of a run, so I had pressed the R key to run the program.. after that, I do not touch the interface again till the job stops..
Another possibility is if you have a GladeVCP tab open. If the mouse cursor is over the GladeVCP then that grabs the keyboard events.
This used to drive me mad on my old Axis lathe, but an MPG works better than the keyboard in every way and is a complete fix :-)
The following user(s) said Thank You: Leon82
27 Feb 2019 12:12 #127240 by Leon82
Replied by Leon82 on topic ESCape key issues in Pre1-4587 build ???
I've noticed If you click off the window, like the desktop it won't respond to keyboard shortcuts either
Time to create page: 0.120 seconds
