- Thank you received: 4
Some info on the installation. The first time I tried dpkg -i it seemed to remove all the :armhf packages. It then returned an error message re unmet dependencies. Then I did sudo --fix -broken install, this still gave an error message at the end of a long list of fixes, so I tried dpkg -i again and it installed.
hobbyno1 wrote: The physical pins respond to the linux o/s and halrun and halcmd seem to work fine. What I seem to need is to rewrite the file hal_pi_gpio.so for the nano. Can you give me any guidance on this or how I might start it.
thx
