Mounting the Camera Was the Easy Part
14 Jun 2019 05:15 #136865 by ictponder
Mounting the Camera Was the Easy Part was created by ictponder
Routed the 30' of cable through the router, mounted to spindle super legit style. Go to install camera like it's Windows 10 and get slapped with a big dose of NOPE for three days now.
Been trying to get the CamPY zip from Bogey to work using this thread
So far the only thing I've been able to do is manually download and install the usbutils from the Debian archive to see if it's even plugged in. Whenever I try to apt-get anything it just gives 404's not found or missing dependancies. I tried to update the source list and Debian said there are no suitable servers, at least in the US. How do I install anything if every repository address is wrong?
Running Weezy
14 Jun 2019 06:01 #136866 by Clive S
14 Jun 2019 07:39 #136868 by pl7i92
Replied by pl7i92 on topic Mounting the Camera Was the Easy Part
you do not need any software or driver
if it is a USB cam it shoudt be fine out of the box
just start chees from a therminal and get a look at your cameras view
it is even more easy as in windooooof
you may have now complicated it as you did harme the alredy installed drivers
WITH closed Chees
and under DISPLAY in your ini
EMBED_TAB_NAME = Camera
EMBED_TAB_COMMAND = camview-emc -w {XID}
restart Linuxcnc and thats it
14 Jun 2019 13:38 #136876 by ictponder
Replied by ictponder on topic Mounting the Camera Was the Easy Part
I tried that but I will double check to make sure they are correct
14 Jun 2019 13:40 - 14 Jun 2019 14:26 #136877 by ictponder
It doesn't look like Chees is even installed on the machine. Can't get USB wifi stick to install either so I have to lug the whole machine up front to connect via ethernet to try. Currently trying to find an extra router to extend range to the back.
Edit: Trying to install chees this is what I get
xxx@cnc:~$ sudo apt-get install chees
[sudo] password for xxx:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package chees
Last edit: 14 Jun 2019 14:26 by ictponder.
14 Jun 2019 15:41 #136888 by pl7i92
sudo apt-get install cheese
[sudo] Passwort für cnc:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
cheese ist schon die neueste Version (3.28.0-1ubuntu1).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 148 nicht aktualisiert.
SORRY for the Missspelling
14 Jun 2019 15:52 #136891 by ictponder
Yeah i saw the typo but it didn't help heres what I get
xxx@cnc:~$ sudo apt-get install cheese
[sudo] password for ben:
E: Unable to locate package cheese
18 Jun 2019 13:23 #137183 by ictponder
Is there a way to manually download cheese from the web? I cannot find it anywhere in the wheezy repository. Tried installing cheese-common and it also cannot be found.
18 Jun 2019 15:31 #137198 by pl7i92
wheezy
DID you follow the UPDATE tread on Reposity END OF LIVE no Packets found
in the Anouncment tread
forum.linuxcnc.org/29-forum-announcement...-repositories#135506
then the APT will do as you want
18 Jun 2019 16:27 #137204 by ictponder
Yes
After source list is updated it still tells me it's unable to located package cheese
Time to create page: 0.161 seconds
