Unexpected realtime delay error message
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
04 Jul 2019 01:29 - 04 Jul 2019 04:32 #138593 by thefabricator03
Unexpected realtime delay error message was created by thefabricator03
Hi Guys,
I am getting the following error messages on my plasma machine when the machine is halfway through a long cut,
Unexpected realtime delay on task 0 with period 1000000,
This message will only display once per session,
Run latency test and resolve before continuing,
hm2/hm2_7i76e.0 Smart Serial port 0;
DoLt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0sserial.0.fault-count;pin will indicate if this is happening frequently.
hm2/hm2_7i76e.0 error finishing read! iter=283342
After I get these errors the machine will continue to give folllowing errors,
I am running Linux mint LMDE RT kernel I downloaded with Synaptic manager.
Any idea what is going on?
Last edit: 04 Jul 2019 04:32 by thefabricator03.
04 Jul 2019 02:05 #138597 by pl7i92
Replied by pl7i92 on topic Unexpected realtime delay error message
hi
what is your latency of the pc
and how is the watchdog initalizised
hm2_7i92.0.watchdog.timeout_ns 10000000
i think there is some zeros missing
can you post your ini and hal if posible
so we can check all entries
  • thefabricator03
  • Visitor
  • Visitor
04 Jul 2019 02:22 #138603 by thefabricator03
Replied by thefabricator03 on topic Unexpected realtime delay error message
Please see below for my latency test results, I had it running for half an hour,
And I have attached my Hal and INI to this post.
  • Moderator
  • Moderator
04 Jul 2019 06:49 #138614 by tommylight
Replied by tommylight on topic Unexpected realtime delay error message
That night be caused by the intel ethernet
Search the forum for coalescence, that might help. Again, assuming you have and intel board since the latency looks fine and having excursions on the servo thread. Seen that a lot on 2 Dell E6510 and a Lenovo T420S i use for testing.
04 Jul 2019 08:10 #138623 by PCW
Replied by PCW on topic Unexpected realtime delay error message
This could be due to a couple of things, it could be a Ethernet latency issue
or it could be you have completely lost contact with the card due to
1. Power supply problems at the 7I76E end
2. A problem with the 7I76E,host or cable
When your system is running normally for some time (no errors) run this command from a terminal:
halcmd show param *.tmax
This (and the clock speed of your CPU) will indicate if its a marginal timing issue
Also if you get an error, check dmesg for any link up/down events:
dmesg | tail -50
Also posting your hal/ini files might give a clue
The following user(s) said Thank You: tommylight, mkardasi, thefabricator03
  • thefabricator03
  • Visitor
  • Visitor
04 Jul 2019 16:35 #138646 by thefabricator03
I posted them in the third post.
04 Jul 2019 17:59 - 04 Jul 2019 18:00 #138651 by PCW
So the hal/ini files look OK.
To determine whats happening, the timing information
(and your CPU clock speed since the tmax numbers are in units of CPU clocks )
would be helpful.
also noting if the link was lost (via dmesg) would help
Last edit: 04 Jul 2019 18:00 by PCW.
  • thefabricator03
  • Visitor
  • Visitor
04 Jul 2019 20:31 - 04 Jul 2019 20:32 #138658 by thefabricator03
Ok there are the values of halcmd,
plasma@plasma:~/linuxcnc-plasmac$ halcmd show param *.tmax
Parameters:
Owner Type Dir Value Name
39 s32 RW 6755 debounce.0.tmax
30 s32 RW 0 hm2_7i76e.0.read-request.tmax
30 s32 RW 1190409 hm2_7i76e.0.read.tmax
30 s32 RW 102827 hm2_7i76e.0.write.tmax
23 s32 RW 6919 motion-command-handler.tmax
23 s32 RW 83173 motion-controller.tmax
33 s32 RW 4446 pid.s.do-pid-calcs.tmax
33 s32 RW 9905 pid.x.do-pid-calcs.tmax
33 s32 RW 3391 pid.y.do-pid-calcs.tmax
33 s32 RW 5521 pid.y2.do-pid-calcs.tmax
33 s32 RW 5490 pid.z.do-pid-calcs.tmax
36 s32 RW 18479 plasmac.tmax
24 s32 RW 1350822 servo-thread.tmax
And the values of dmesg after the error occurs.
plasma@plasma:~/linuxcnc-plasmac$ dmesg | tail -50
[11094.897955] sd 6:0:0:0: [sdc] Mode Sense: 23 00 00 00
[11094.900832] sd 6:0:0:0: [sdc] No Caching mode page found
[11094.900833] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[11094.920588] sdc: sdc1
[11094.933333] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[11095.354215] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[15266.093096] perf: interrupt took too long (3939 > 3937), lowering kernel.perf_event_max_sample_rate to 50750
[15934.868745] intel_powerclamp: Start idle injection to reduce power
[15938.872943] intel_powerclamp: Stop forced idle injection
[16311.257054] intel_powerclamp: Start idle injection to reduce power
[16315.261257] intel_powerclamp: Stop forced idle injection
[16827.650355] intel_powerclamp: Start idle injection to reduce power
[16831.654614] intel_powerclamp: Stop forced idle injection
[17485.613726] usb 2-1.7: USB disconnect, device number 9
[18110.231756] intel_powerclamp: Start idle injection to reduce power
[18114.234807] intel_powerclamp: Stop forced idle injection
[22335.969886] e1000e: eno1 NIC Link is Down
[22350.805129] usb 2-1.7: new high-speed USB device number 10 using ehci-pci
[22350.942743] usb 2-1.7: New USB device found, idVendor=18a5, idProduct=0302
[22350.942746] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22350.942747] usb 2-1.7: Product: STORE N GO
[22350.942748] usb 2-1.7: Manufacturer: Verbatim
[22350.942749] usb 2-1.7: SerialNumber: 900093C1F5275B15
[22350.943026] usb-storage 2-1.7:1.0: USB Mass Storage device detected
[22350.943085] scsi host6: usb-storage 2-1.7:1.0
[22351.956745] scsi 6:0:0:0: Direct-Access Verbatim STORE N GO 5.00 PQ: 0 ANSI: 6
[22351.969304] sd 6:0:0:0: Attached scsi generic sg3 type 0
[22354.486338] sd 6:0:0:0: [sdc] 30322688 512-byte logical blocks: (15.5 GB/14.5 GiB)
[22354.490326] sd 6:0:0:0: [sdc] Write Protect is off
[22354.490327] sd 6:0:0:0: [sdc] Mode Sense: 23 00 00 00
[22354.493201] sd 6:0:0:0: [sdc] No Caching mode page found
[22354.493202] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[22354.512956] sdc: sdc1
[22354.525827] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[22354.942591] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[22797.808328] usb 2-1.7: USB disconnect, device number 10
[87975.423069] usb 2-1.8: USB disconnect, device number 8
[87975.820331] usb 2-1.8: new low-speed USB device number 11 using ehci-pci
[87975.934182] usb 2-1.8: New USB device found, idVendor=1a2c, idProduct=2124
[87975.934184] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[87975.934186] usb 2-1.8: Product: USB Keyboard
[87975.934187] usb 2-1.8: Manufacturer: SEM
[87975.936925] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/0003:1A2C:2124.0008/input/input20
[87975.996485] hid-generic 0003:1A2C:2124.0008: input,hidraw1: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:1d.0-1.8/input0
[87975.999633] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.1/0003:1A2C:2124.0009/input/input21
[87976.056422] hid-generic 0003:1A2C:2124.0009: input,hidraw2: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:1d.0-1.8/input1
[87979.194425] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[87979.194429] e1000e 0000:00:19.0 eno1: 10/100 speed: disabling TSO
[88288.356358] intel_powerclamp: Start idle injection to reduce power
[88292.357979] intel_powerclamp: Stop forced idle injection
Last edit: 04 Jul 2019 20:32 by thefabricator03.
  • thefabricator03
  • Visitor
  • Visitor
04 Jul 2019 21:07 #138659 by thefabricator03
Attached is the CPU specs,
04 Jul 2019 21:26 #138660 by rodw
Replied by rodw on topic Unexpected realtime delay error message
I'm no expert with Linux but that looks like a HDD hardware fault or a corrupt disk
That would do it. maybe run fsck as suggested and see what happens
Time to create page: 0.117 seconds
