Unexpected realtime delay error message
- thefabricator03
- Visitor
05 Jul 2019 02:33 #138662
by thefabricator03
Replied by thefabricator03 on topic Unexpected realtime delay error message
Ran Fsck and got the following message,
plasma@plasma:~/linuxcnc-plasmac$ fsck
fsck from util-linux 2.29.2
e2fsck 1.43.4 (31-Jan-2017)
/dev/sda2 is mounted.
WARNING!!! The filesystem is mounted. If you continue you ***WILL***
cause ***SEVERE*** filesystem damage.
Do you really want to continue<n>? no
check aborted.
I did have some drama installing the OS with having to stuff around partitioning the drives and mounting them.
check aborted.
- Thank you received: 5334
05 Jul 2019 02:33 - 05 Jul 2019 03:02 #138663
Replied by PCW on topic Unexpected realtime delay error message
[88288.356358] intel_powerclamp: Start idle injection to reduce power
[88292.357979] intel_powerclamp: Stop forced idle injection
Looks like you have some kind of power management still enabled
This may indicate that your CPU is overheating, or if you dont have a heatsink/fan
issue that you need to disable power management
(you can check your CPU temperature with "sensors")
Last edit: 05 Jul 2019 03:02 by PCW.
- thefabricator03
- Visitor
05 Jul 2019 02:42 #138664
by thefabricator03
I will try that, Thank you PCW,
The computer is older so might be on its way out.
- Thank you received: 4151
05 Jul 2019 02:46 #138665
Replied by rodw on topic Unexpected realtime delay error message
Clutching at straws, but it says you have a removable USB disk installed. Maybe remove it and reboot. That message I saw may have been to do with it.
- thefabricator03
- Visitor
05 Jul 2019 02:50 #138666
by thefabricator03
Yeah I thought that as well, I did that yesterday, Removed the usb stick and restarted with no luck.
05 Jul 2019 03:03 #138667
If this just started happening it might be as simple as a stuck fan
- thefabricator03
- Visitor
05 Jul 2019 04:30 #138670
by thefabricator03
It definalty has been overheating, I didnt realize that the CPU has a fan less cooler on it, It was very hot to the touch.
- thefabricator03
- Visitor
05 Jul 2019 07:39 #138677
by thefabricator03
Ok guys, I brought another used computer and installed linuxcnc and ran the latency test, Are these numbers OK since I am using a Mesa 7i76e,
05 Jul 2019 07:45 #138678
That should be fine
05 Jul 2019 13:33 #138686
On your old machine, are you missing the plastic duct that goes from the fan to the CPU cooler? (its missing in the picture)
Time to create page: 0.121 seconds
