Unexpected realtime delay error message
05 Jul 2019 14:12 #138692 by pl7i92
Replied by pl7i92 on topic Unexpected realtime delay error message
how did you configure yor interface eth
#7i76e PL3 2019
auto eth0
iface eth0 inet static
address 192.168.1.4
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
dns-nameservers 8.8.8.8 4.4.4.4
hardware-irq-coalesce-rx-usecs 0
do you got this inside your interfaces
sudo gedit /etc/network/interfaces
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
07 Jul 2019 04:20 #138766 by thefabricator03
Replied by thefabricator03 on topic Unexpected realtime delay error message
Thanks to everyone who helped especially PCW,
The new computer is working well. My old PC was probably missing the plastic fan duct and was overheating.
  • Moderator
  • Moderator
19 Jun 2022 15:31 #245436 by tommylight
Replied by tommylight on topic Unexpected realtime delay error message
@DoWerna
Moved your post to "driver boards" and renamed to reflect the issue, this is not the same as "unexpected realtime delay" errors.
forum.linuxcnc.org/27-driver-boards/4617...t-not-cleared#245435
09 Jul 2022 22:05 - 09 Jul 2022 22:11 #246983 by dannym
Replied by dannym on topic Unexpected realtime delay error message
I've had the latest ISO running on a fanless J1900 PC for a couple of weeks.  Mesa 7i92 card (ethernet).
I believe the shop air temp would be below 27C.  The J1900 box doesn't have a mount and has been placed at various angles.  I do recall latency test being ok, I will check it again.  This error didn't ever occur on the prior Dell PC running 2.6 RT Preempt, I'm assuming this is related to the new hardware.  It was an old Dell but low latency.  That Dell is still there.
This is a makerspace with many users and has been running tens of hours since upgrading, and this is something reported, I'm not aware of any unusual circumstances.  It threw this error once, and they had to restart their job:
"Unexpected realtime delay on task 0 with period 1000000
This message will only display once per session. Run the latency test and resolve before continuing. "
So, it's rare.  I don't know of a way to reproduce this, it just happened once and did not reoccur AFAIK.  It's only thrown it once in tens of hrs AFAIK, although I did hear someone else say "it just stopped once" for them and no more info about any error message.
Could this be J1900 overheating, or could it be this "IRQ coalescing" problem?   I'm leaning towards an overheating issue since it has only showed up rarely.
The only thing that comes to mind would be to TRY to overheat the PC by putting a blanket over it or something.
Should I try to increase the SERVO_PERIOD=1000000?   I'm thinking not, as it operating ok for many hrs and it was fine with the old Dell.
Last edit: 09 Jul 2022 22:11 by dannym.
  • Moderator
  • Moderator
09 Jul 2022 23:08 #246991 by tommylight
Means the servo period is already set at 1000000 (1 million), so no need to change that.
I did have a J1800 i think a few years back, it would lock solid for no reason about once every 1 to 5 days, it is still in daily use.
I never could figure out why it was doing that, but adding a fan over it's cooler did help a lot, as it would go for months without locking. Not sure what is was as the fan was blowing over everything on the board, so i blamed the voltage regulators and moved on.
In case the locks are becoming more often, changing the power supply would be first on the list.
10 Jul 2022 01:28 #246993 by dannym
It's an external wall wart, but I figured if anything went wrong with it, we'd see a reboot or freeze, not just an error message in LinuxCNC.
But I can imagine if it overheats, the BIOS might lower clocking to the system or some part of the system (like the ethernet), which could clearly create a latency problem.
However, if it were overheating, I'd also expect that once it did it, it would predictably repeat the problem in a few minutes after rebooting and restarting the job, if nothing else is changed.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
10 Jul 2022 12:41 #247013 by Todd Zuercher
Replied by Todd Zuercher on topic Unexpected realtime delay error message
The J1900 based mb I am using for mythTV struggled for years with random lock ups. It was mostly due to a kernel bug for that chipset. There is a range of Linux kernels that just won't work with them.
10 Jul 2022 16:41 - 10 Jul 2022 18:36 #247024 by dannym
Ouch! Troubling! I spent a lot of time getting this right on this box.
Do you know of a better fanless mini PC for this?  Or any others I might want to avoid?
Last edit: 10 Jul 2022 18:36 by dannym.
11 Jul 2022 01:45 #247047 by dannym
If I swap to another sort of PC, can I just swap the hard drive?  I did go through significant hassle recompiling the code for the VFD and deploying a bug fix.  Is it ok if it's another Celeron?
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
11 Jul 2022 02:50 #247050 by Todd Zuercher
Generally yes. Possible exceptions if you used UEFI to install.
Time to create page: 0.416 seconds
