- LinuxCNC
- General LinuxCNC Questions
- can linux cnc can cut a thread using only breakout board without using mesa card
- Dinuka_Shehan
- Thank you received: 26
07 Jul 2019 08:14 #138785
by Dinuka_Shehan
can linux cnc can cut a thread using only breakout board without using mesa card was created by Dinuka_Shehan
I am new to linux cnc.
i am using cheap 5$ cnc breakout board and Tb6600 stepper drivers.
can i cut with threads with using only quadrature encoder without using expensive mesa cards.
- pl7i92
- Thank you received: 358
07 Jul 2019 08:43 #138786
by pl7i92
Replied by pl7i92 on topic can linux cnc can cut a thread using only breakout board without using mesa card
YES
you can connect a simple Induktiv Switch or a low cost encoder 100ppr to the China BOB
with a 100ppr you will be able to perform realy good treading on a lathe
getting only one signal per rotation is working also you need to drive in and out longer saying 5 turns in 2 turns out
while 100ppr is near zero
200k is the limit of the inputs at this board
the 100ppr will be times by 4 as the edge trigger so you get 400signals per rotation
there are also 25ppr out but the 100ppr is the most used and cheepest
Homemade ones also work
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
08 Jul 2019 06:36 #138840
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic can linux cnc can cut a thread using only breakout board without using mesa card
Thank you for reply.
i am using this bob and going to use this encoder 2000ppr.
can i use 2000ppr encoder for this
- pl7i92
08 Jul 2019 07:50 #138843
by pl7i92
no a 2000ppr is way to mutch for this board
it is a 200k bord max so only 100rpm may be working but i guss it can only take 50rpm on a 2000ppr
while on a 100ppr it takes about 1000rpm
you can only use pin10 as the encoder as it is the fastest parport input
- Dinuka_Shehan
08 Jul 2019 08:19 #138846
by Dinuka_Shehan
how to connect and there are coding for that?
pwm settings in stepconfig how to fill it?
- Dinuka_Shehan
08 Jul 2019 08:26 #138847
by Dinuka_Shehan
pwm
- pl7i92
08 Jul 2019 15:36 #138867
by pl7i92
you can use the phaseA
it is only needed
in
linuxcnc.org/docs/html/man/man9/encoder.9.html
if you like to get indexing for real RPM it is also to be connected here
it is only needed
in
- pl7i92
08 Jul 2019 15:43 #138869
by pl7i92
here is a example
loadrt encoder
addf encoder encoder.capture-position servo-thread
addf encoder.update-counters base-thread
net rawquada parport.0.pin-10-in encoder.0.phase-A
net rawquadb parport.0.pin-11-in encoder.0.phase-B
YOU may see some jitter if so use Debouce
loadrt encoder
loadrt debounce cfg=2
addf debounce.0 base-thread
net rawquada parport.0.pin-10-in debounce.0.0.in
net rawquadb parport.0.pin-11-in debounce.0.1.in
net cleanquada debounce.0.0.out encoder.0.phase-A
net cleanquadb debounce.0.1.out encoder.0.phase-B
loadrt encoder
loadrt encoder
- Clive S
- Thank you received: 486
08 Jul 2019 17:05 #138877
by Clive S
Replied by Clive S on topic can linux cnc can cut a thread using only breakout board without using mesa card
I think you need Index and A to do threading. For ridged tapping you need index +A + B
- Dinuka_Shehan
08 Jul 2019 17:06 #138878
by Dinuka_Shehan
I'm just new to linux cnc.
I want to know how to add this code to my settings.
- LinuxCNC
Time to create page: 0.119 seconds
