- LinuxCNC
- General LinuxCNC Questions
- can linux cnc can cut a thread using only breakout board without using mesa card
- Thank you received: 4648
16 Jul 2019 16:30 #139576
A multimeter in diode testing mode should tell you which is the LED.
Then you can try driving that with 5mA or so, and see what the other pins do.
One of the little component testers might also be useful:
www.ebay.co.uk/itm/323851908270
(As a randomly chosen example, not as a specific recommendation)
Replied by andypugh on topic can linux cnc can cut a thread using only breakout board without using mesa card
I have already got some old photocopiers optocoupler switches but the problem is I can not figure out the pins of those switches.
any ideas?
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
- Thank you received: 26
16 Jul 2019 16:38 #139579
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic can linux cnc can cut a thread using only breakout board without using mesa card
max rpm should be 3000rpm
phase A and index pulse
can i add phase B to my system?
16 Jul 2019 17:01 #139582
What is your actual base period? That will decide whether quadrature is possible.
You would also need another input pin, and an extra sensor.
- Dinuka_Shehan
16 Jul 2019 20:50 #139598
by Dinuka_Shehan
Hi Andy,
I don’t remember the exact value right now.
Can you please explain me what is actual base period?
What is for (purpose)?
What are vital factors and limitations?
I’m excited to know.
I have little idea about latency test.
But base value always confuse me.
16 Jul 2019 21:00 - 17 Jul 2019 00:52 #139602
The base thread period is the period (in nanoseconds) at which the encoder counts will be sampled.
If the value is 20000 nS (20µS) then the sample frequency is 50kHz.
So, if the A / B transitions come more frequently than 50kHz you are likely to miss some of them.
Last edit: 17 Jul 2019 00:52 by andypugh.
- Dinuka_Shehan
16 Jul 2019 21:18 #139605
by Dinuka_Shehan
From where 50Hz came from?
I am currently install linux cnc to
Pentium 4 D processor 1Gb ram 128 onboard VGA included desktop pc.
What is the highest base thread value to perform threading precisely.
I think I should run latency test first.
But I think you will have a better solution!
Thank you for help you gave me so far and as well as other members
16 Jul 2019 22:19 #139621
50kHz = 1/20µS
50kHz = 1/20µS
- Thank you received: 7465
16 Jul 2019 22:26 #139623
Replied by tommylight on topic can linux cnc can cut a thread using only breakout board without using mesa card
@Andy
There is 1 zero to many on the base timing.
@DinukaShehan
50kHz, not 50Hz. 50kHz is 50000Hz, or Hertz, or signal changes per second.
Regards,
@DinukaShehan
Regards,
- Dinuka_Shehan
17 Jul 2019 07:45 #139673
by Dinuka_Shehan
what should be my base thrread value?
17 Jul 2019 07:53 #139674
Assuming you want to use parallel port , you need the RTAI version of the kernel for that computer, and if it is good as some Dell P4D i had you can safely use 50000 for the base thread.
Linuxcnc will let you know if the base thread is to fast, so start from that and if you do get real time errors, raise it a bit and test again
- LinuxCNC
Time to create page: 2.377 seconds
