- LinuxCNC
- General LinuxCNC Questions
- can linux cnc can cut a thread using only breakout board without using mesa card
- Thank you received: 7465
22 Jul 2019 07:58 #140161
Replied by tommylight on topic can linux cnc can cut a thread using only breakout board without using mesa card
No install, it works automagicaly !Should I install driver to parallel port to make it work?
- Dinuka_Shehan
- Thank you received: 26
22 Jul 2019 14:45 - 22 Jul 2019 14:46 #140179
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic can linux cnc can cut a thread using only breakout board without using mesa card
Last edit: 22 Jul 2019 14:46 by Dinuka_Shehan.
- Dinuka_Shehan
22 Jul 2019 14:49 #140180
by Dinuka_Shehan
Is Graphic card vital for linuxcnc?
all brands works for linux:once I read Nvidia and amd not support for linux
- Thank you received: 4648
22 Jul 2019 14:56 #140182
Replied by andypugh on topic can linux cnc can cut a thread using only breakout board without using mesa card
It is probably best to start off using the motherboard graphics, only fit a separate card if you have reason to believe that the onboard graphics is causing a problem.
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
22 Jul 2019 15:24 #140188
by Dinuka_Shehan
My ram is 1Gb is it enough?
22 Jul 2019 15:32 #140192
For Ubuntu 10.04 and Debian wheezy it is usable.My ram is 1Gb is it enough?
- Dinuka_Shehan
22 Jul 2019 15:36 #140194
by Dinuka_Shehan
linuxcnc-2.7-wheezy and downloaded
Is this latest version ?
can I work with both on 1Gb
22 Jul 2019 17:25 #140205
Yes that should work.
- Dinuka_Shehan
24 Jul 2019 08:08 #140411
by Dinuka_Shehan
විස්තර
චතුරස්රාකාර කේතන යන්ත්රයකින් ජනනය වන ස්පන්දන ගණනය කිරීමෙන් පිහිටීම මැනීමට එන්කෝඩරය භාවිතා කරයි. මෘදුකාංග මත පදනම් වූ ක්රියාත්මක කිරීමක් ලෙස එය දෘඩාංග වලට වඩා බෙහෙවින් අඩු වියදමකි, නමුත් සීමිත උපරිම ගණන් අනුපාතයක් ඇත. පරිගණකයේ වේගය සහ වෙනත් සාධක මත පදනම්ව සීමාව 10KHz සිට 50KHz දක්වා පරාසයක පවතී. වඩා හොඳ කාර්ය සාධනයක් අවශ්ය නම්, දෘඩාංග කේතීකරණ කවුන්ටරය වඩා හොඳ තේරීමකි. සමහර දෘඩාංග මත පදනම් වූ පද්ධති MHz මිල ගණන් යටතේ ගණනය කළ හැකිය.
එන්කෝඩරය උපරිම නාලිකා අටකට සහය දක්වයි. මොඩියුලය පටවන විට ඇත්ත වශයෙන්ම පටවා ඇති නාලිකා ගණන num_chan තර්කය මඟින් සකසා ඇත. විකල්පයක් ලෙස, කොමා මඟින් වෙන් කරන ලද නම් = සහ අද්විතීය නම් සඳහන් කරන්න.
අංක_චාන් = සහ නම් = පිරිවිතරයන් අන්යෝන්ය වශයෙන් වෙනස් වේ. Num_chan = හෝ නම් = නියම කර නොමැති නම්, හෝ num_chan = 0 නියම කර ඇත්නම්, පෙරනිමි අගය තුනකි.
එන්කෝඩරයට කවුන්ටරය නමින් එක්-අදියර ඒක දිශානුගත මාදිලියක් ඇත. මෙම ප්රකාරයේදී, - B අදියර ආදානය නොසලකා හරිනු ලැබේ; phase A අදියරෙහි එක් එක් නැගී එන අද්දර ගණන් වැඩි වේ. චතුරස්රයේ ශබ්ද-ප්රතිරෝධී ලක්ෂණ නැති වී ගියද, තනි ආදාන රේඛාවක් සහිත ඒක දිශානුගත භ්රමණය ගණනය කිරීම සඳහා මෙම ප්රකාරය ප්රයෝජනවත් විය හැකිය
- LinuxCNC
Time to create page: 0.280 seconds
