Plasmac parport connections
7 years 3 months ago #139399 by phillc54
It would be parport.0.pin−<n>−in or parport.0.pin−<n>−in-not.
I don't know what that error means.
If you are using a frequency then you probably need to feed that into an encoder then use the velocity output of the encoder for the arc voltage.
Are you using a THCAD?
7 years 3 months ago - 7 years 3 months ago #139402 by phoenix
Replied by phoenix on topic Plasmac parport connections
I didn't connected it to my parport physically
I'm using diy circuit
But leave that as it's other topic
FOR NOW I JUST WANT MY AXES TO JOG INSIDE PLASMAC... EVEN A SINGLE AXES JOG ALSO ENOUGH
Last edit: 7 years 3 months ago by tommylight. Reason: removed offending line
7 years 3 months ago #139408 by phillc54
Can you post your ini file and ALL your hal files and I will have a look tomorrow.
7 years 3 months ago #139409 by tommylight
@Bushan
Stop making ofending comments.
What is your native language ?
From the begining:
Do you have a THC like THCAD or Proma THC150 or similar?
From your posts you mentioned several times that you do not have a THC, so why do you insist on using such a config ?
Make a simple config and use the machine, you can use a simple DC motor instead of the Z axis motor with two switches to lower or raise the torch while cutting.
For PlasmaC you need to have a working normal config then use the PlasmaC manual to see what you need to edit and what to copy where.
7 years 3 months ago #139427 by bevins
Replied by bevins on topic Plasmac parport connections
Bushan,
The docs clearly states one of the first things to do is get a working config. Which has nothing to do with Plasmac.
Get your machine working and jogging three axis before doing anything with a Plasmac config.
7 years 3 months ago - 7 years 3 months ago #139435 by phoenix
sorry for my arrogent behaviour earlier
is this right
or do i need to make any changes in ini and hal files of my base config
thanks
oppps sorry theres an out pin for torch on
Last edit: 7 years 3 months ago by phoenix.
Time to create page: 0.060 seconds
