Plasmac parport connections
7 years 3 months ago #139526 by phoenix
Replied by phoenix on topic Plasmac parport connections
Yes sir i m going to convert voltage to friquency using 555 and get that in from parport
I will provide files as soon as possible
I tried manually editing files and it started for a moment and then crashed again
7 years 3 months ago - 7 years 3 months ago #139650 by Grotius
Replied by Grotius on topic Plasmac parport connections
@Phoenix,
You learn quickly...
PLS STOP CONFUSING ME AND JUST SIMPLY TELL ME HOW TO OR WHERE TO DO PARPORT CONNECTIONS IN YOUR DAMN CONFIG :angry: :angry: :angry:
to :
Yes sir
Take your time... And it will bring you luck... More luck then then windows and mac together...
Last edit: 7 years 3 months ago by Grotius.
7 years 3 months ago #139653 by rodw
Replied by rodw on topic Plasmac parport connections
Here is a tip: Always start linuxcnc from the command line. That way when it crashes, you can study the messages in the console window it usually will print a useful error. say "pin xyx does not exist". so then you know where to look. sometimes its useful to comment out the line that is causing the error so you can run Linuxcnc and use halshow to observe the actual pin names. It might just be a typo or something in your hal file. When you see what it should be you can fix it and remove the comment.
7 years 3 months ago #140066 by phoenix
as someone suggested i commented out my arc-ok in and torch on out pins and my config runs but as soon as i uncommented them it says that resp pins not found
i moved my arc-ok in pin from baseplasma_connections.hal to baseplasma.hal and arc-ok in prob solved
but its still saying that parport.0.pin-8-out which is torch-on pin not found what can i do about that ???
7 years 3 months ago #140071 by phillc54
You can read the answers you were given to this question on the other thread that you asked on...
7 years 3 months ago #140077 by phoenix
sorry but i tried to find thread you are talking about and unable to find one
these are my files as u can see i cant connect arc ok pin but when i use test panel its woeking pretty great
why it doesnt accepting parport pins also tried copy pasting
Time to create page: 0.205 seconds
