Plasmac configurator not working
7 years 2 months ago #141915 by PCW
If you used a pre-calibrated analog float value, would you set scale to 1 and offset to 0?
7 years 2 months ago #141939 by phillc54
I think that is how rodw and islander261 have their settings.
7 years 2 months ago #141955 by rodw
PCW wrote: If you used a pre-calibrated analog float value, would you set scale to 1 and offset to 0?
Yes, Phill had an early bug so we just decoded the torch voltage outside of plasmac and set scale and offset to 0 like we had always done.
7 years 2 months ago #142082 by andypugh
phoenix wrote: I'm not intended to offend any of u but I'm sick of getting same eror again and again its just say parport. 0.pin-8-out doesn't exists
It is parport.0.pin-08-out
6 bit IN FALSE parport.0.pin-01-out 6 bit IN FALSE parport.0.pin-02-out 6 bit IN FALSE parport.0.pin-03-out 6 bit IN FALSE parport.0.pin-04-out 6 bit IN FALSE parport.0.pin-05-out 6 bit IN FALSE parport.0.pin-06-out 6 bit IN FALSE parport.0.pin-07-out 6 bit IN FALSE parport.0.pin-08-out 6 bit IN FALSE parport.0.pin-09-out 6 bit OUT FALSE parport.0.pin-10-in 6 bit OUT FALSE parport.0.pin-10-in-not 6 bit OUT FALSE parport.0.pin-11-in 6 bit OUT FALSE parport.0.pin-11-in-not 6 bit OUT FALSE parport.0.pin-12-in 6 bit OUT FALSE parport.0.pin-12-in-not 6 bit OUT FALSE parport.0.pin-13-in 6 bit OUT FALSE parport.0.pin-13-in-not 6 bit IN FALSE parport.0.pin-14-out 6 bit OUT FALSE parport.0.pin-15-in 6 bit OUT FALSE parport.0.pin-15-in-not 6 bit IN FALSE parport.0.pin-16-out 6 bit IN FALSE parport.0.pin-17-out
Time to create page: 0.278 seconds
