- Thank you received: 4153
15m Industrial Plasma Cutter
7 years 1 month ago #144228
Replied by rodw on topic 15m Industrial Plasma Cutter
Every machine will be different depending on how you lay it out. My limit switches are within 2-3mm of the hard endstops.
A good length might be 1600mm rail with a 1400mm rack. On my Y axis, this gave me 1264mm of travel but my carriages are further apart there than on my X.
The following user(s) said Thank You: Jarman
7 years 1 month ago #144233
Replied by andypugh on topic 15m Industrial Plasma Cutter
I have never even seen a plasma cutter, so take this idea as purely theoretical.
But I think this could make a good floating mount:
uk.rs-online.com/web/p/slide-unit-actuators/1244615/
The idea being that after the probe the air pressure can be increased to lock the head down to avoid false-tripping by vibration.
- pl7i92
- Thank you received: 358
7 years 1 month ago #144234
by pl7i92
Replied by pl7i92 on topic 15m Industrial Plasma Cutter
7 years 1 month ago #144236
There are definitely cheaper ways than the pneumatic cylinder. I only really proposed that as an off-the-shelf unit to save time.
The cylinders also have provision for mounting solid state switches in a range of styles and types: uk.rs-online.com/web/c/?sra=oss&r=t&searchTerm=D-M9
- Jarman
- Thank you received: 8
7 years 1 month ago #144335
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Ok, I am thinking of using a Nema 23 for my z axis, as used in this design.
www.veloxcncrouters.com/xz-za-series
Does LinuxCNC and 7i67E interface well with hybrid steppers? Do you guys using steppers have rotary encoders?
7 years 1 month ago #144337
Yes. I think normally, the closed loop steppers are closed on the stepper driver so Mesa and Linuxcnc don't care. Wait for others to respond because I think feedback can be closed in Linuxcnc but it may not be worth the complexity.
Nema 23 is fine. I use 269 Oz/in Nema23 on mine
Time to create page: 0.265 seconds
