- Thank you received: 2100
15m Industrial Plasma Cutter
- phillc54
7 years 2 months ago #142888
by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
Yes, I broke that, it should have been fixed hererodw wrote: Phill, the issue I experienced today is that your configurator on an upgrade creates a spindle pin for the engraver even if you don't have an engraver. So once he sorts out the permissions, that change will fix the problem until you fix your configurator.
The following user(s) said Thank You: Jarman
- phillc54
7 years 2 months ago #142890
by phillc54
All good, I was wondering why I saw "twopass:found /usr/share/linuxcnc/hallib/basic_sim.tcl" in your error report.
I didn't realise you where just running sims.
Did you copy the original sim directory and make changes where needed?
Jarman wrote: I fixed the permission issue and commented out the line, my simulation now runs as it used to.
Thanks for the help.
- Thank you received: 7491
7 years 2 months ago #142891
:laugh: :laugh: :laugh:
Replied by tommylight on topic 15m Industrial Plasma Cutter
How could you ???phillc54 wrote: Yes, I broke that, it should have been fixed here
- phillc54
7 years 2 months ago #142892
by phillc54
HaHa, It was really easy to do...
- Thank you received: 4153
7 years 2 months ago #142897
Haven''t you built that machine yet? Its only a tiny one, I thought you'd be able to knock it over in an afternoon ....................... ?
Replied by rodw on topic 15m Industrial Plasma Cutter
Jarman wrote: my simulation now runs as it used to.
- phillc54
7 years 2 months ago #142899
by phillc54
HaHa, I thought the same with mine.
The following user(s) said Thank You: rodw, Jarman
Time to create page: 0.842 seconds
