- Thank you received: 8
15m Industrial Plasma Cutter
- Jarman
7 years 2 months ago #142835
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks Rod,
I tried to do that myself earlier but didn't have permission to save. I'll figure out how to open as administrator and then see if it works.
- phillc54
- Thank you received: 2100
7 years 2 months ago #142836
by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
You shouldn't need administrator permissions, you config directory should be in your home directory, something like /home/jarman/linuxcnc/configs/
I would not recommended that you comment lines out, I would rather find out what the real problem is so we don't have issues down the track.
Could you zip your config directory and I can take a look tomorrow.
The following user(s) said Thank You: Jarman
- Thank you received: 4153
7 years 2 months ago #142837
Replied by rodw on topic 15m Industrial Plasma Cutter
Phill, the issue I experienced today is that your configurator on an upgrade creates a spindle pin for the engraver even if you don't have an engraver. So once he sorts out the permissions, that change will fix the problem until you fix your configurator.
- Jarman
7 years 2 months ago #142840
by Jarman
Thanks guys.
I have attached my configs directory
- Jarman
- Jarman
7 years 2 months ago #142850
by Jarman
I fixed the permission issue and commented out the line, my simulation now runs as it used to.
Thanks for the help.
Time to create page: 1.507 seconds
