- Thank you received: 4153
15m Industrial Plasma Cutter
7 years 2 months ago #141675
Replied by rodw on topic 15m Industrial Plasma Cutter
I would report issues with Plasmac on this thread
forum.linuxcnc.org/plasma-laser/35449-an...component?start=1440
I thought I saw the guys discussing some of your issues in the last day or so so it may have been fixed by now but not in the packaged version yet.
Because Plasmac has only recently been added to the distribution versions, a lot of users compile LinuxCNC from source as we had to to get it installed. That means we can update as soon as updates have been pushed to master branch.
The following user(s) said Thank You: Jarman
- Jarman
- Thank you received: 8
7 years 2 months ago #141679
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks for that, I'll have a read.
I think I have fixed my issue, made my own G-code converter. Seems to work.
- phillc54
- Thank you received: 2100
7 years 2 months ago - 7 years 2 months ago #141708
by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
I think the latest update will fix your issues.
If not could you post the gcode that is causing any problems.
Edit: could you also post the error that it produces.
Last edit: 7 years 2 months ago by phillc54.
- Jarman
7 years 2 months ago #141762
by Jarman
Hi Phill,
I have made my own G-code conversion tool that seems to be working so far (converting files from inkscape).
All it does is remove the movement Z commands and adds "M3 S1" before the first movement block. Is this too simplistic and should I go about getting the update? I notice for example that THC velocity lock is always on, however the files now load into plasmac and the simulation runs.
Thanks.
Thanks.
- Thank you received: 7491
7 years 2 months ago #141765
Replied by tommylight on topic 15m Industrial Plasma Cutter
You do not need that, there is a plasma tool in Inkscape already, in the gcodetools menu under tools choose plasma. For comfortable use it has to be modified a bit to remove some stuff that is there for probing, but that can also be removed during editing of the drawing.
Here is a quick video with no commentary on how to output gcode for Linuxcnc.
The following user(s) said Thank You: phillc54, johnmc1, Jarman
- phillc54
7 years 2 months ago #141767
by phillc54
Whatever works for you is good, I would like to find out why the PlasmaC GCode parser is not working for your GCode.Jarman wrote: Hi Phill,
Thanks.
The following user(s) said Thank You: tommylight, Jarman
Time to create page: 0.477 seconds
