15m Industrial Plasma Cutter
7 years 2 months ago #142812 by rodw
Replied by rodw on topic 15m Industrial Plasma Cutter
I'm not so sure that the configurator will fix it based on my experience updating plasmac from master branch source code. But definitely run it.
This is the error
twopass: Error in file ./plasmac.hal: Pin 'spindle.1.on' does not exist
I had the same problem today.
So for the OP, just open plasmac.hal file and comment out the line containing spindle.1.on by prefacing the line with a '#'
This has been added to allow control of a pneumatic engraver using the multi spindle feature.
Phill, I think that if the engraver pins are not entered, this line should be commented out or omitted when running the configurator.
The following user(s) said Thank You: Jarman
7 years 2 months ago #142813 by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
Actually I think he may not have run make
7 years 2 months ago #142815 by rodw
phillc54 wrote: Actually I think he may not have run make
But I did about lunch time but I think I'm already 3 versions behind !
7 years 2 months ago #142820 by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Yeah I didn't run make. Just the two commands I posted above.
Is there a specific command I should be using to do that?
Thanks.
7 years 2 months ago #142824 by rodw
Jarman wrote: Yeah I didn't run make. Just the two commands I posted above.
Thanks.
Basically, copy the buildbot line in the link Phill posted and paste it onto the command line
If you still get the error, then comment out the line as I suggested.
7 years 2 months ago #142827 by phillc54
I don't think I had my brain in gear, it seems you are using a buildbot install so you don't need to run make.
Could you open a terminal and run man plasmac and let me know the version number.
Time to create page: 0.566 seconds
