- Thank you received: 8
15m Industrial Plasma Cutter
- Jarman
7 years 2 months ago #141774
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks Tommy, I have already been following that tutorial and using the plasma features of Inkscape. My problem occurred when I tried to open those files in plasmac. My Inkscape files open directly into sample-sim-axis but not plasmac.
I'm struggling to take a screenshot in Linux but when I try to open one of the files in plasmac I get the message:
G code error in spiral.ngc
"Near line 16 of /tmp/tmp9NQ9wK/spiral.ngc
Bad character ')' used
If I press "OK", no preview loads but I can see the G code in the bottom right window.
Line 16 reads:
g1 x33.566083 y5.468631 f200.000000 (z-1.000000))
I believe that the second closed bracket is the problem. The brackets are consistent like this throughout the code.
The original line in the code from inkscape reads:
G01 X33.566083 Y5.468631 Z-1.000000 F200.000000
I have created a script that removes the Z term, changing it to:
G01 X33.566083 Y5.468631 F200.000000
This seems to work.
Also, as soon as the plasmac window opens (with no file) I get errors:
PIERCE_HEIGHT is missing from material #0
PIERCE_DELAY is missing from material #0
CUT_HEIGHT is missing from material #0
CUT_SPEED is missing from material #0
But these do not seem to be causing problems.
Thanks.
Line 16 reads:
This seems to work.
Thanks.
- Jarman
7 years 2 months ago #141785
by Jarman
Would you guys who have built plasma cutters recommend building a small scale model first (Given the size and my lack of experience)? Bearing in mind I don't have a whole lot of time to get this done (not much more that 5 weeks).
Thanks.
Thanks.
7 years 2 months ago #141792
Replied by andypugh on topic 15m Industrial Plasma Cutter
Maybe build the short axis first, make a 1D plasma cutter.
The following user(s) said Thank You: Jarman
- Thank you received: 7491
7 years 2 months ago #141800
Replied by tommylight on topic 15m Industrial Plasma Cutter
You should take Andy's advice and start making the Z axis with floating head, then make the X axis and mount the Z axis to it. That will help a lot when you start the big Y axis.
- Thank you received: 4153
7 years 2 months ago #141818
Replied by rodw on topic 15m Industrial Plasma Cutter
With the timeframe, I would buy a prebuilt Z axis stage and just make the floating head slide and magnetic breakaway. I know I was doing it in my spare time but it took me 3 months to built the complete Z axis assembly.
- phillc54
- Thank you received: 2100
7 years 2 months ago #141827
by phillc54
You really should use FF#<_hal[plasmac.cut-feed-rate]> as described here to take advantage of Velocity Anti Dive and you onlt require one F word at the beginning of your code.
Replied by phillc54 on topic 15m Industrial Plasma Cutter
The parser didn't like the F word in the line, I have fixed it and will push an update later today.G code error in spiral.ngc
Line 16 reads:
They WILL cause problems when you try to cut, they are mandatory .Also, as soon as the plasmac window opens (with no file) I get errors:
Time to create page: 0.430 seconds
